Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
We’re currently investigating an issue related to the forum theme and styling that is impacting page layout and visual formatting. The problem has been identified, and we are actively working on a resolution. There is no impact to user data or functionality, this is strictly a front-end display issue. We’ll post an update once the fix has been deployed. Thanks for your patience while we get this sorted.
i have a Kia Sorento diesel the engine keeps popping the oil dipstick out is this because the engine is presurising? If so is there an easy solution.thanks for taking the time to read
Crankcase over-pressure does sound like the issue - there will be breather pipe(s) to take the inevitable piston blow-by gases into the inlet circuit for re-ingestion, these may be blocked - or the piston rings are so badly worn that too much gas is escaping from the combustion chambers.
As Roger says,its going to breath,everything breaths to a degree it has too.But at 100k i would still expect bore/ring wear to be low.Unless of course its been hot.More like a breather is blocked or turbo pressure is entering the crankcase.Perhaps even an injector sleeve/seal issue.
Ask on this Kia Forum. They have some fantastic experts.
http://kiasorento.proboards.com/
My last Sorento was pxd at 136000, no smoke , sweet as a nut.
It sounds very much like a blocked breather. You say she stills pulls well so I assume you haven't noticed any loss of power or smoking from the exhaust.
