KOJACK LITE!!
Oct 22, 2009
586
Hi, HIMSELF ordered one of these after I found a post on another site. They are usually £80+ and this company are doing them for £49.99 +£4.99pp.worldofcamping.co.uk) I am not good with links!!!
Thursdays Child
1,649
Can you remember when Kojak was a bald guy called Telly Savalas with a penchant for lollipops?
mel
Sep 25, 2009
372
Hello Tony,
I found this site and the Kojack offered is the scissor type, the pricing is 45euro + carriage at 12.9euro for delivery. This = approx
Sep 25, 2009
372
Thanks Sproket, I have printed the information for both jacks and will keep it on file, until I decide what to do.
Dean, tell me having levelelled the van, do you leave the jack in place or do I have to purchase other supports to keep it level and then remove the jack? Sorry if this is a basic question, but as I indicated I am waiting to get my first van in May and have a big learning process to go through.
Best regards,
George
Jul 1, 2009
2,142
no i pack with small off cuts of ply in diffrent thickness low cost but many people use this method/then keep jack in front bo x so i dont have to dig out car jack .Imade a smallcoler to put on top of jack and cup the jack point on van.
Sep 25, 2009
372
Hello Dean,
Thanks this makes more sense than leaving the jack in place. I had in my mind that you would place the alternative support under the chassis, and you have cleared this up for me.
Thanks for your help it is appreciated.
Best regards,
George
Nov 5, 2006
805
Hi Bedford George,I have tried most types of jack with my van & have settled for the scissor Kojack for the following reasons.
Bear in mind that jacks should not be used under the chassis of a caravan,only under the axle or using proper brackets that fit to the locations provided by ALKO Remember that in the case of a flat tyre the space under the caravan axle is very limmited
Trolley jack, weighty & difficult to place under the axle awkward to store in car / van. Pyramid 12 volt jack, blowes fuses if trying to use from the near closed position,& the suplied brackets tend to bend allowing the van to slip off the jack.
Small bottle jack, will not fit under axle,& even if brackets are fitted will not fit under them with a flat tyre
ALKO side lift jack with the supplied brackets is quite good but expensive for a new one
Kojac scissor will go low enough to fit in the supplied brackets,& is easy to use both with motor mover & spare wheel carrier in place,easy to use for leveling the van on site But you need to take into consideration the settlement of the van suspension when placing blocks under the wheel.
Hope this answers your question
Nov 5, 2006
805
forgot to say it is also suitable for your car, so you can leave that at home,less weight to lug around
Sep 25, 2009
372
Hello Tony,
Thanks for this comprehensive explanation, I think it looks like I need the scissor type Kojak. As I thought there is more to this than meets the eye, if you want to do it properly, and I am on a steep learning curve. I have found the Forum extremely helpful in many ways, and will continue to read the various threads as they arise.
Best regards,
George
Reg
Jan 12, 2008
435
I suggest you try using a scissor jack in its lower position by placing blocks under it before you finally make up your mind.
I found it impossible to get enough leverage on the handle to lift the caravan. The jack needs to be open to about halfway before you can start lifting the van.
I have changed to a bottle jack and am constructing my own brackets to ensure I have the height space needed when the tyre is flat. I am fortunate in having access to a workshop with welding equipment etc.
As I stated before at Toolstation the "identical" jack to the Kojack one is only
