- Jun 6, 2012
- 11
- 0
- 0
Hi All, I don't know which forum to post this one in, so if I ought to put it under another one, please advise. We are looking at buying a Bailey Pageant Series 5 2007 for 5K, clean condition, but the only problem is it has had a leak in the roof by the trim. Apparantly this has been fixed though it is currently measuring 54% damp, (everywhere else is 8%) and we are not sure if that means it is still leaking, or that it was not properly dried out when it was repaired. Being new to caravaning, does anyone have any advice as to : A - How bothered should we be about this leak that is measuring 54% damp (whatever that actually means) though is apparantly fixed - ie would you think that means it is not fixed?B - Once a caravan has a leak, can it ever be truly fixed, or will it always be a weak spot? If it can be fixed, how costly can we expect it to be?C - Is this fairly normal? - Particularly with this model? Is it a glitch? Are we expecting too much to buy a caravn up to 10 years old for 5K with no damp/leaks?D - Would you go with the purchase, or would you steer clear? Many thanks for all your help.
