LED's again
May 5, 2005
1,154
Want some LED bulbs for van and can't see them on ultraleds site.They are 35mm dia 12v halogen10watt,also would like to fit extra LED striplights,what are "drivers" for do I need them,also why does it say on some of the 12volt LED striplights "not for car use" bit technical for me I'm afraid
Jun 19, 2006
53
Hi Dave. If you go onto E bay and search for item 300190375539
this will show you direct relacement bubls for the caravan. If you want to play about yourself go to www.goodwillsales.com. They are cheap and very helpful. Nigel.
Jul 6, 2007
265
The bulbs we have in our home kitchen light came with a rubber sucker that sticks to the glass and allows you to twist the bulb.Do not lick the sucker to make it stick,it slips!!!!
My son used the sucker on a childs arrow from a bow & arrow set!!
Aug 8, 2007
394
Ahem!
Mr Thicky at the back here.....
Please indulge me -
Is it possible to convert my halogen spotlights in my van to LED's?
Advice much appreciated.
Mac
Sep 13, 2006
1,411
MR11 bulbs are push in types so do not try to twist them.
On ours there is a spring clip which can be released with finger and thumb and then the bulb just drops out.
You do not need to worry too much about touching the surface of the bulb as the halogen bulb is a separate bulb within the envelope, although it can still get very hot if you have just had them on.
We have changed to LEDs and are very happy with them, although I would say the radiated colour is not as "warm" as the halogens.
