Leisure batteries
Sep 1, 2022
91
12
85
Going to have to purchase a battery for our Abbey vogue gt216 caravan as our caravan does not have one there is not much space in the compartment for the battery-possibly size of a small car battery? and we have a motor mover on the caravan any suggestions please? as I do not want to buy the wrong one for the job.
3,924
Most caravans that have a battery compartment fitted as standard will accept at least an 80 Ah leisure battery, and often a 110 or 120 Ah leisure battery. Either battery when properly charged should successfully operate a caravan mover.
However. Whether you need such a big battery will depend on how you intend to caravan. For example. If you want to caravan without access to mains power, then you will need the biggest leisure battery you can fit. But if you only ever use pitches with mains power then you could get away with a much smaller standard car battery just to run the caravan mover.
It often comes as quite a surprise how little total power a caravan mover needs for example most caravanner's typically use less than 2Ah of battery charge to position a caravan on site, or into storage. This is because the motors are not running for very long. But whilst the total power used is surprisingly small, the motors on some movers do need up to 40A each (but most are closer to a peak current of about 20A each) as motors begin to turn. The battery needs to have a big enough starting or cranking current to supply the peak current demands. As soon as the motors are turning their current demands drop significantly, so you don't actually need a battery with a big capacity.
If your not sure about your type of usage, your better to hedge your bets and go for the largest leisure battery that will fit in your battery box.
4,705
In addition to the Prof’s post measure your housing and allowing for the terminals , wiring and fuse you should be able to find one that fits. Also ask on the Lunar Owners website .
1,818
You do need to check the size of the battery box to check how large a battery you need. Do allow a bit extra to get it in connected up. Ideally you need a 110 a/h battery but you should be able to get away with a 80a/h one if you are only manouvering into site pitches and say a storage area. If like us at one time you have to take it up a fairly steep drive then the larger battery is needed. They are generally rated as A, B and C for use age and a B is correct for a mover although with light use you can get away with a lesser one. The caravan is a light model so should not be too great a drain on a battery.
Oct 3, 2013
890
90
18,935
What are the dimensions of the battery compartment.
Sep 1, 2022
91
12
85
Thankyou for your help
4,624
I doubt if the Lunar Owners Club could assist as it is an Abbey caravan.
Reactions: Challenger
3,941
Measure your battery compartment and go to Halfords. They are good for sizes.
