Leisure Battery
Mar 19, 2007
36
Any one ever hooked up an extra leisure battery to run along with their normal battery in the van. Just a point the battery I have aquired is out of a HGV and is 1050 Amps but still 12v, anybody see any drama's with this set up. It's just that I will be going to a ralley for 3 weeks and begrudge buying a solar panel if I don't have to.
Jun 2, 2008
12
make sure you get the terminals the right way round or you will make it into 24v volt system, which will fry you 12v items.
just a note about putting such a high power battery along side a normal one is that the high power one might draw the power from the lover one causing damage to it, i would sujst just swaping the batterys over not running them together.
oh one more thing would the charger in you van be up to the job of charging such a big battery,
reguards mike
Jan 31, 2008
282
The batteries would have to be wired in series to become 24 volts. Getting the terminals "the wrong way round" would result in a short circuit and cause the batteries to get hot and even explode.
And putting a higher powered battery next to a lower powered one will cause the higher powered battery to be drawn down to a lower power similar to that of the existing lower powered one.
When putting two batteries together they should ideally be of the same size (power) and age.
Jun 2, 2008
12
what i ment by wrong way round was that linking the in seris would cause 24v and parallel would be a 12v system with a higher ampage, you would only cause a short circuit by reversing the polarity, or linking the possitive and negitive terminals of the same battery.
Mar 19, 2007
36
Thanks for the advice fella's, I won't be charging off my caravan charger as I plan to use the battery just for the essentials, you know water pump etc.
3,600
Hello Barry,
As others have said, there can be serious problems when running batteries in parallel.
I really think the safest solution is to use a single battery at a time, and change it when necessary.
