Hi - I have an abbey Iona with motor mover fitted - can anyone advise me which size of battery would be best suited to my unit - empty weight 728kg laden weight 920kg
ProfJohnL said:The NCC;s scheme to rate batteries is probably a good idea, but you need to be able to identify your usage pattern and the look for appropriate batteries.
I do find Ray's answer somewhat confusing, As far as I can see Saint spoon made no recommendation as to the category, and as far as this thread is concerned there has been no indication the way Thosonill's is trying to use it.
As for the strain a mover puts on a battery, apart from the initial start up surge which lasts a matter of a fraction of a second or so, the running current drain should be well within the capacity of all caravan batteries in good condition.
saint-spoon said:ProfJohnL said:The NCC;s scheme to rate batteries is probably a good idea, but you need to be able to identify your usage pattern and the look for appropriate batteries.
And your point is? How do you recommend a battery if you don't know what the intended use will be? A somewhat obscure answer.
