Lexus Towing Problem
Jul 19, 2006
My RX300 2005 model has a very uncomfortable ride when towing Hymer Nova 435. Does anyone else have this problem - it's a bit like being at sea. I've been told this may be to do with the air suspension and its also an issue with the new Range Rover. Lexus blame it on the caravan and Hymer blame it on Lexus...what a suprise! Any suggestions?
May 21, 2008
2,463
Hi Clive.
It might be stating the obvious, but check your loading stratergy of the van. Have you got too much weight at the front and then put weight at the back to compensate. Loading the weight over the axle helps. Also the hitch weight should be about 75Kgs.
After that I'd get the load compensation valve checked on the suspension of your Lexus, this is supposed to dampen or stiffen the travel to suit road and load conditions.
You don't mention a stabiliser, I use a snake master (leaf spring type) on my Laguna for towing my twin axle van. while I don't require it as such as the unit is sway free, I do find it helps to control the yawing up and down. You see my van is inherantly too heavey at the front, and I have to put all the water canisters and waste canisters in the back bedroom of the van to get 75Kgs of hitch weight ( my car's tow bar weight limit). Being 24 years old, I guess Dean line were not too worried as they expected a landrover to be the tow car and they can carry a heck of a lot more on the rear.
Good luck and i hope you resolve the prob.
Steve.
