Little tap things by water pump input on outside of Carvan!?
Apr 13, 2005
1,210
NORMAN, as ray has already stated the little white things that look like taps are simply to hold your pump in to the holder. they are very fiddeley but need to be used to stop the pump working loose.
as has been said they are small lugs that when you fit pump into housing top one pushes down bottom one pushes up (i use small screwdriver)as tokeep the pump in place
