Long time no see.
Jul 16, 2006
61
Hi Guys,
Sorry I haven't been around for a while. Pressures of work and family I am afraid. I do however need your help. I have a set of Comet Nova sink taps on my caravan, one of which leaks after its turned off. I have managed to source a repair kit. I would have replaced the mixer tap but some smart designer decided that underneath the sink was a sensible place to put the fridge. Not wanting to remove the fridge, I want to repair the tap. What I wanted to know (and someone on here must have done it) is how does the plastic insert with the washers on, come out? I would be most grateful if someone can tell me.
All the best,
Don
Sep 21, 2007
258
16
18,685
Not quite the answer you want but just for info as I understand it you can remove the top fridge vent from outside to gain access to the tap, so you don't have to remove the fridge. Obviously as you haven't said which caravan you have I could be wrong.
Mike
