Loose wheels and ATC
Mar 25, 2025
5
I've only been towing for 3 years, so if this has been discussed before I'm sorry.
I had a wheel detached and strike a car recently.
I had caravan stored at home on axle stands.
The wheels were free running.
I checked the 130nm wheel bolts as soon as it was on the ground.
On the day of travel I hitched up and did the usual lights, jockey wheel,hitch AND checked the wheel torque again.
We set off and I noticed a slight tugging whilst towing. I thought it was the wind or bad road surfaces. Nevertheless we stopped at the first layby 5 miles from home and did a visual and checked nothing was loose.
Satisfied we resumed our journey. Still feeling a tugging sensation we decided to stop again at the next layby.
We didn't make it, it was only 15 miles from home.
A wheel detached and struck a car, no injuries, luckily.
On inspection the brakes were toasty , really hot.
Whilst waiting for recovery, a couple of people stopped. They said "that's happened to me!"
In the end my wife went home to get my trolley jack, and a helpful neighbour for backup.
We managed to get it up , quite difficult when it's sitting on the motor mover axle.
Are you still awake!!!
I'm surprised at the blasé attitude of the caravan industry.
We went to the local caravan centre.
The fitter came out and we told our story.
"I bet it's the nearside wheel" he said.
Right first time, I replied.
"We've had a few of these"
He explained about how to fit wheel correctly.
I asked what were causes? " Can't always tell, it just happens sometimes"
What about heat? " That can be a cause".
So I thought back to the tugging feeling and the heat in the brakes.
On further investigation it appears, if you have an intermittent 12v supply "the ATC can go through it's check cycle whilst on the move.
Heated brakes explained......maybe!
I noticed a poorly fitting 12v 20 amp supply fuse.
This supplies the ATC . Also a not quite closed junction block under caravan.
Who knows?
We're booked in for an expensive brake drum and shoes, a wheel box wheel spat, possibly a wheel etc.
Well done if you read up to here!!
Questions for the caravan community.
1 why do you accept poorly designed overpriced parts?
2 why does no one investigate these issues?
The wheel issue could be partially solved by a spigot for locating the wheel. If the bolts slacken the wheel should hold on.
Penny pinching car manufacturers choose safety over cost. Caravan industry choose fat margins over safety.
At present nearside bolts only have to slacken slightly, the wheel is then eccentric the bolts then rapidly part company, and the wheel then looks for a victim.
Offside wheels don't suffer as much from this problem, as it's trying to tighten the wheel bolts.
A simple positive locking device for the wheel bolts.
An ATC button.
Connecting the 13 pin would enable the ATC.
The button or key switch would be used solely for a test cycle and show green led if it's OK.
On the move the ATC would not recycle with intermittent voltage.
The other advantage would be no led showing if a fault was detected on the journey.
But the ATC would still be active and would encourage investigation if no led was showing.
Phew! Thanks for reading.
That's another 10 Minutes of your life you won't get back!
3,842
Some time ago, 10 to 12 years ago Bailey recalled their caravans for wheels coming loose, this was to do with the type of bolts being used.
There has been much debate about the direction of rotation and wheel bolts coming loose but again nothing proven.
Glad you didn't have a physical accident to yourself or others.
7,893
After their spate of problems Bailey introduced the WSL bolt which then was marketed for other caravans. Although at the time other makes did not seem to be having wheel problems, so perhaps Baileys wheels may have contributed to the problem.
But by checking torque before setting off you did the right thing, and your wheel detached at a distance less than normally recommended for a second check if wheels have been removed and refitted. Your comments wrt ATC do seem to have some validity, but I’ve never heard them before.
Hope you get it sorted.
If you search on the Forum for WSL you get lots of hits.
Apr 23, 2024
138
112
135
Thanks for the heads up and no it wasn't boring or overly long winded as it conveyed important information based on personal experience and an odd issue with a faulty ATC system and a reminder to all to physically check the wheel nuts for tightness with a wrench , not just visual. and the centre of the alloy rim for a temperature rise. It also highlights a possible failure mechanism of alloy wheels on Alko trailers , extreme heat causes the bolts to come loose( rim softening ?). . On Australian caravans I saw a video where the brake control was a dial and warning button in the cab of the car, the rig had crashed despite the brake control See
View: https://youtu.be/xD735nwYDQk
. You can also get wheel bolt position indicators like they have on HGV vehicles.
833
I am convinced that the issue affecting Bailey caravans is due to them not coordinating adequately with AlKo engineers in the selection of their alloy wheels. After all, AlKo supplied the same chassis to other caravan manufacturers without a problem, so it must be a specific issue affecting only the alloy wheels that Bailey used.
It's difficult to comment on the ATC issue on the case in question without a thorough technical investigation and analysis.
The video above is not really very revealing. The electrical braking systems employed on Australian outfits do not meet European requirements, so it doesn't tell us very much.
2,906
I am convinced that the issue affecting Bailey caravans is due to them not coordinating adequately with AlKo engineers on the selection of their alloy wheels. After all, AlKo supplied the same chassis to other caravan manufacturers without a problem, so it must be a specific issue affecting only the alloy wheels that Bailey used.
Aren't electric brakes now permitted in Europe - having previously been illegal for decades.
833
They are legal, but they must not involve any manual intervention as in the case of Australian (and American) electric brakes, and they must be type approved.
3,727
1,488
The ATC's pre use safety test, going through a full cycle, IMO can't reasonably be criticised because it also means it throws up defective powering issues. Very much to the contrary, it makes that powering defect very evident, and of course without powering the ATC is useless.
Here the action is to either sort the powering defect, or temporarily for that trip disable it, so it can't intermittently power the ATC.
I would like to have an ATC system that proves to me it is working before I leave, rather than face the possible outcome during a trip, it was not.
Reactions: Jcloughie
3,727
1,488
Spigot fitted wheels, as viable in "user changeable" vehicle road wheels, does nearly zero in retaining the wheels. To be "user changeable" the spigot system has to be a clearance fit, so as a consequence a loose wheel would shuffle on the spigot.
Our wheels, cars and caravans are in respect to radial loading, solely held on by friction, this generated by the level of tension in the bolts or studs clamping, the wheels to the hub.
Once that required level of tension is lost, most typically because of settlement or "give" , the wheel starts moving as the radial load rotates round. That movement then results in the bolts/nuts turning and or the components smashing each other up . Consequently the wheel very soon comes free spigot or not. No bolts, smashed or lost, then no retention. Bolts don't turn until there is already an issue.
Key here in retaining the wheels is the tension retained in the bolts, it must be adequate so the wheel can't move, move and failure follows, often very quickly.
The mentioned WSL bolts use the centuries old engineering principle that the longer the worked length of the bolt, the more tolerant is the tension level retained, for any given settlement or give in the clamping system.
WSL bolts offer about three times the ability to retain an adequate tension level for a given amount of settlement, that the basic bolts had, even at like for like torque ups.
5
I found it hard to describe the test button proposed for the ATC.
The way I was thinking was.
1 Connect 13 pin plug, this applies power to ATC.
2 press test button and make ATC cycle as normal.
Green LED all ok.
3 should the power be interrupted during travel the ATC would still be powered after it re- connected .
The only difference would be a blank LED at end of journey or coffee stop.
Still powered and no worse than present setup.
Blank LED would indicate there had been a fault.
The way the ATC works now. The LED would show green and pretend it's all been fine.
( Nothing to see here! I'm green so I've been ok all the way).
Finding an intermittent fault is your worst nightmare.
If your driving it's difficult to see the LED.
Bad road surfaces can give the same impression as brakes.
This wheel detached in the space of 15 miles.
I stopped after 5 miles and intended to stop at the next layby total 16 miles. I only made 15 of those miles!
Mine test cycles, and turns green.
I attached a video camera under the caravan,
( focused on the balance stirrup ) and did a short test run. Every thing looked ok.
I could be making the facts fit my thoughts.
But this was after I had tightened up the 12v 20a fuse and charged the car battery.
Smart alternators seem to keep car batteries at a low charge
I bought a cheap plug in volt meter, you'd be surprised at the way the alternator charges.
1 I intend to fit infrared sensors to the brakes.
2 I will fit a backup camera focused on the nearside wheel.
3 I'm in the process of designing and making a positive wheel nut locking device. ( In metal as 3d printing in plastic is inviting it to melt if the brakes get hot).
4 nut indicators give the user false security. At least they are brightly coloured when pick them up with your detached wheel.
Maybe it's over the top but I don't want a repeat of this event.
Mar 25, 2025
5
A cars front wheels have driven,stop and turn.
A caravan only brake.
I agree bolts don't turn until there's an issue.
Fail safe is a good motto.
3,727
1,488
I would suggest that positively locking the bolts from turning will only delay an outcome till they are smashed up.
Wheels coming loose can readily happen before they had start to even try and turn. Them turning is a consequence of being loose, not the cause of coming loose.
IMO if you can't trust the integrity of the ATC powering set up, would it not be cheapest and more effective to have an electric warning of lost of ATC power; a drop out relay sounding a klaxon powered by the van's battery?
The ATC by design test cycles if powering is lost, on being re-established.
So unless you alter this aspect of the ATC it will cycle on re powering following an intermittent lose of power.
What the LEDs indicate is a side issue.
IMO it would be quite wrong to fundamentally alter the ATC's proven operating system, just to over come having dicky powering; sort the powering issue not the ATC. I suspect if any insurer is involved a DIY disabling mod to the ATC would be grabbed at with some enthusiasm.
5
Not sure about the locking device.
But the aircraft industry use positive locking and it tends to work.
Your other point about power supply is valid.
I'm going to set up a voltmeter and variable resistor and power the ATC with a battery. I'll then turn down the voltage and see where it drops out .
Then I'll connect a voltmeter to the car and see what's the lowest voltage coming from there.
It's possible the car is the fault.
I appreciate all the advice I'm getting. Hopefully when it's solved I'll share the knowledge we've gained.
3,727
1,488
But do they for anything like a similar bolting system, one designed to frictionally carry a radial rolling load? Indeed bolt locking is well practiced but is only relevant where the application benefits from it.
You also wire lock them for example where a free loose bolt can itself be a hazard.
Here as explained, all you will achieve is a short delay whilst the forces get to work smashing up the bolts, and here they are in the scale of things quite puny and not applied as "fitted shear bolts", just tension loading bolts.
As said earlier our wheels are held in radial loading by friction, not by shear.
IMO, you are way better going the WSL route; they IMO know the problem and the solution, not that it is novel or new. A technique I have used myself to cure a client's bolting system failures, one very like this. I have zero connection with the WSL company, nor have I been a customer.
5
Just for information the wheel bolts are 10.9
Grade 10.9 bolts have a minimum tensile strength of 1040 MPa (145,000 psi).
Here's a more detailed breakdown:
  • What is a Grade 10.9 bolt?
    These bolts are known for their high strength and are often used in applications requiring high clamping forces or where safety is critical.
  • Material:
    They are typically made from alloy steel that has been quenched and tempered.
    • Other Properties:
        • Yield Strength: They have a minimum yield strength of 940 MPa.
        • Hardness: They typically have a hardness range of 32-39 HRC.
        • Elongation: They have a minimum elongation of 9%.
3,727
1,488
I don't understand the relevance in the context here of your wheel coming off?
The issue, in every probability is they came loose, not that they were or were not of a material capable of being done up adequately tight enough.
That you torqued them proves they were capable; something happened post that to reduce their tension, and with that the easing of the clamping force, and following that, allowing the wheel to move relative to the hub. Once there, it all unravels quickly.
Sam Vimes
2,179
1,725
I won't pretend to understand much of this because I don't have ATC but there's one thing I picked up on. That's that there maybe a condition where the ATC is recycling because the supply voltage is dropping and restoring.
This immediately brought to mind the problems of some smart alternator systems whereby the voltage is dropped when the smart system changes the alternator output to reduce loading on the engine.
This happens on my car and one result is that the caravan fridge cycles on/off when towing because the voltage it gets is too low.
Of course you're problem may be nothing like this but I mention it as something to consider.
Reactions: ProfJohnL
3,727
1,488
ATC has been in use along with smart alternator technology for years, so I suspect Al-Ko were aware and designed the ATC to live with them.
I have never encountered any ATC intervention that was not directly associated with a dynamic activity of the van, the very thing it is designed to sense. It is though, dumb in that it does not differentiate those dynamic situations associated with other conditions where the van could snake or would not. eg it sometimes intervenes rolling at walking pace on a rough field.
Here we already know the supply fuse holder was a sloppy fit. That system really needs a proper service; evidence elsewhere indicates ATC used with healthy power supply systems has no such issues, despite there now has to be countless modern vehicles using smart technology alternators. Like much, ATC requires a healthy environment, it does not counter poor powering.
3,727
1,488
As said, things can go critically wrong long before one can stop and see a bolt has turned. If they ever show one had, then one can count themselves exceptionally fortunate they ever got that far to see that!
Quite a different argument can be made for bolting systems with way more than just 5 bolts, where missed proper tightening attention to an individual is more likely. eg lorries and buses.
The issue needing attention is not the bolts turning, but the bolt loosing tension; this can happen without it turning.
Relying on just noting if even only one of a five bolt system has moved, rather then they are all tight is dangerous so all a bit pointless.
2,906
There's no reason in theory why smart alternators would affect ATC operation - the system voltage will never drop below battery voltage but can be higher during charging cycles, ie vary between 12 and 15 volts - the ATC will accept that range of voltages, possibly going even lower as it's designed to function when active for 24 hours to reset the memory, so the engine is not going to be running that long.
Reactions: otherclive and JTQ
3,727
1,488
Exactly Roger.
During ATC action the current draw will depress the achieved voltage at the ATC, but even that effect would not be an unknown to Al-Ko's designers.
Evidence of countless of us not having issues, strongly suggests that the OP's problem was not smart alternator related.
7,893
What make and year is the caravan ? I’m assuming through this conversation that it’s not a Bailey from the period where wheels did become detached, or another make with non OEM wheels? Just a thought as has been said ATC, alloy wheels and smart alternators aren’t exactly new to caravans.
Sam Vimes
2,179
1,725
Not entirely true and may differ between cars depending on implementation.
On my car the voltage in the car varied on pin 10 between 0 (engine off) to 14.24 dropping to 12.9 after a few minutes (engine on).
While these voltages might be deemed to be in spec. at the towbar connector, poor wiring in caravans - including mine - can cause further drops. My fridge has a low 12v voltage detection cct. I can't remember the low voltage drop out point and true the fridge has a higher loading than an ATC - none the less my fridge drops in and out if I try to power it when towing. Others have reported the same.
Dodgy wiring in tow bar kits and connectors may also contribute to voltage drops.
There are different implementations of Smart Alternator systems. Some cars have no problems with towing caravans in respect of fridges and battery charging.
Others need work arounds like turning on headlights or air con to prevent the Smart function kicking in.
Other folks fit DC-DC convertors between the car and caravan to restore the voltage back to the required level.
This may not be relevant to the OPs problem but something to consider.
833
Correct matching of material is most definitely the most important factor regarding the way the fastener retains or does not retain its clamping torque. The elastic limit of the alloy used in the wheel may be too low to prevent material flow in the course of applying dynamic loads to the system, and, over time, that would result in a loss of torque. In such a case, steel bushes should be inserted in the alloy wheel at each bolt location.
