Hi Guys
I don't intentionally load to maximum, I have a problem with nose weight. The van sits at 70 kg with nothing in the locker. I carry gas bottle in the locker - have moved the spare to a carrier, place the heavy box of toilet liquids / jacks over the axle. minimize weight in the front and put the aquaroll / waste hog in the back. I empty the water cylinder to travel which is front O /S, as is the battery which weighs 28.6 kg. As someone said here in the last day or two you get to know how to load the van, to travel best - and although I would have preferred less weight on the nose it tows well, but I agree the front of the car is sensitive to caravan deflection. Interested in feedback to my tyre pressures (17 inch wheels). Last trip I carried an awning over the axle, but it was too heavy and on the return trip I had to move it as far back as possible.
An issue I guess others are aware of is tow height - there seems to be a critical point where the van imposes disproportionately more weight - which causes real problems with stability thence must be avoided, so careful loading of the car is also required. I try hard to get the car to 'sit right' with the caravan and the load, and find the tow height affects the towing / stability, presumably affecting the air flows under and onto the van as speed increases.
