Mar 31, 2025
My caravan has been standing for a year and when I plug in the electrics, all that lights up is the fuse lights :(
Caravan is sterling eccles 584 sport
Any help/advice would be appreciated thanks
Sep 23, 2023
1,173
473
1,435
If you know are competent with electrics I would suggest starting with the Ehu cable,Check between live and neutral pins on the socket first,then you can go from there,good luck ..Gary
Sep 4, 2011
432
219
18,935
Presumably you are talking of the 12 volt fuses with the Green LED below them. If nothing actually works probably the leisure Battery is flat and only just enough volts to light the LEDs
4,984
What year?
Have you looked at the wiring diagram?
Do you have a multi meter? What's the battery voltage?
2,475
Might be best to get AWS Mobile caravan engineer out he will check it and then you have the peace of mind .
4,141
I do not understand what you mean by "Fuse Lights" Fuses don't normally have lights, so I'm wondering exactly what you mean. Can you post a picture of the lights? and tell year of the caravan?
Thank you
