Marine Wax?.
I thought about using Boat polish instead of car or caravan polish as I thought it would give a much tougher and longer lasting finish, what do you think?.
Sounds fine to me, if it's a Silicon type polish you could have a little trouble if you vaer need fibre class or paint chips repaired as Silicon will stop paint and resins from adheering unless cut right back.
Just make sure it is a pure polish, preferably with lots of real carnauba wax, failing that silicone waxes.
Make doubly sure it doesn't have any cutting compounds in the wax - boats are out in the sun all the time and the surface film of GRP or paint tends to degrade - so the cutting compounds wipes off the degraded layer and you have a bright shiny surface. Not a good idea on a car or caravan which have very thin paint layers.
Robert
