marks in window
Feb 12, 2008
79
any one help i have dry marks in between the pains of the front window, was told the two pains have touched one another, causing the marks can this be possible if so how can i remove the marks they are right in your eye line many thanks
936
Simon, unfortunately you cannot remove marks between the panes.
How does it happen?, it happens when you are towing, the force of the air flow causes the outer pane to flex, quite alarmingly at times, which then hits the inner pane.
