Max view external TV point, d’oh!
Feb 13, 2022
553
407
1,135
As part of a bigger project adding some 12V sockets to my lounge area, I decided to replace the existing TV aerial connection point. The existing one had no water proofing, was oxidising and also I wanted to add a satellite connection.
The replacement point covers the hole left by the previous unit got it all lined up to what I thought was perfection…. Then woe, I discovered that the top screw is not clear of the original hole, so just goes into mid air! There seems to be two options for repairing , copious amounts of Soudall sealant around the area which isn’t fully compressed, or very fiddlylong machine screw, but and metal fixing plate job. Made all the more difficult due to the inner part of the socket being down the side of the hot water tank. The latter seems to be the best option. Most frustrating!
2,776
I would suggest that if the body covers all holes, just rely on the Soudall, it will secure better than the screws anyway.
2,776
There is is already the adhesive pad and two screws at the bottom holding it. Are you suggesting sealant around the edges ?
I did not know about the adhesive pad. Personally I would remove that and bed the unit on with Soudall. The screws will hold it while it sets.
