curlyboy said:
Hi and hello(new member) I am having a towbar fitted to my ML350 on monday by Mercedes,£2400,yes there is a lot more to it than just the towbar,the SAM unit that controls the body electronics including back up warnings will need upgrading and a new cooling fan will have to be fitted,as they explained to me,if you sell the car and the new owner has problem towing his 3 ton horse box!! it will come back on the dealer for failing to fit complete system.It is evidently a six/seven hour job @ £112/hour,so you can draw your own conclusion,as I did,as to the suitability of other tow bar installers,incidently I was quoted £546.
curlyboy
ancient chinese proverb....good not cheap...cheap not good.
Labour will be £1k !!!
You must be mad giving all the work to Mercedes!!!
You should get the towbar fitted by a local fitter, cost £600 ( tow bar and electrics are £500 this will be the same westfalia towbar and electrics that are factory fitted) Then take to Mercedes to have the rear SAM unit recoded ( this is for the trailer control, fog light cut out, parking sensors etc), this unit is in the right rear of the of the boot, max 1 hr to do , no parts all software, then have the upgraded fan fitted cost £350 parts and 1 hr labour make sure you get the original fan back.
The car is then as per the recommended spec.They will charge you for a new bumper insert which has the cut out already, but as this is underneath you cant see the cut if you use the original part.
You are paying Mercedes £120 an hour to have someone take a rear bumper off and fit a towbar and replace the bumper, when thats all the fitter will charge to do the whole lot.
You could easily do if for £1200 half of the price from Mercedes for the same job, you will also find that most dealers sub the work out to towbar fitters as they do more and are better at it.
You should ring them up again and ask them for a price to recode and fit fan?
At least the car will come back nice and clean!
