Milenco Leveller
DJP
May 12, 2006
28
Ian,
We got a Milenco 5-6 weeks ago, tried it out but there was no-way it was going to lift our van (1500 kg) off of the ground. On the second attempt, the universal joint coupling just started to fall apart!
Took it back and exchanged it for the Bulldog which is much more substantial although a bit heavier. It also has a less 'fine' pitch to the thread, so less winding is needed to reach the desired level, but a decent ratched with socket will be needed.
DJP
vi
Jun 14, 2006
32
We have a Lockloy and find it very good. It lifts our caravan with no problem (1200kg) and is easy to use, though it can take a little while depending on the amount of adjustment needed.
Vi
