MIRO (Mass in running order) changes
2,400
Trevor_NI said:
WatsonJohnG said:
There are too many Johns
Righteous indignation just gone off the boil
Realise its the higher qualified John in the firing line
You're right : every Tom Dick and Harry is called John
Brilliant!
Jan 31, 2011
316
RogerL said:
Manufacturers have to define what's in their MIRO - in the case of gas cylinders it'll be whatever the caravan manufacturer chooses - it may be 26.8kg to represent 2x 6kg Calor cylinders at 90% capacity - but they may have chosen a completely different cylinder to base their calculation on. There's no requirement that they have to include a gas cylinder if they consider the caravan can be operated adequately on mains electric.
This is the problem with EU harmonisation - it doesn't work accurately if different countries, like UK and Germany, use products in different ways.
That is why I stated that each caravan should be weighed before delivery, then you know just what you can add not to overload it
3,893
But the gas cylinders won't be onboard when it's weighed !
Jan 31, 2011
316
What I am trying to say is if the van weighs 1400 kgs when it leaves the factory & the gross weight is 1600 kgs, you then know that you can only load 200 kgs total & that will include everything gas, clothing & what ever else you load into it
4,465
Which is taking us back towards the more conventional concept of MIRO where the R stands for running which refered to the trailers ability to be towed, rather than being lived in - in essence the Ex Works Weight
Perhaps the new regime should be called Mass In Living Order or MILO or MISO- Mass in Sales Order?
Oct 30, 2009
1,542
but surely that is the point of having the true MIRO and a list of what it contains, essential equipment that the van uses that is not included in the MIRO comes out of the user payload 200kg seems a lot on paper but take the weight of the battery,gas bottles, waste and waterbuts, EHU cable, spare wheel, motor mover, onboard water ect 200kg dosn't look that great then add all the bits and pieces like tv's pot and pans and a awning and it's gone.
the new requrement only applies if your buying new it is easy to see what is included but these vans will be second user in a year or two so how do you know then what is included,
