Mondeo battery feed in the boot?
There are 2 fuses marked "trailer" in the central fuse box but does anyone know if these are wired through to the boot, and if so where would I find them on an Estate? I am wiring the tow bar and I need 2 battery feeds for the bypass relay and the charge relay. You guys have been really helpful with my other questions so I hope you can give me the right answer this time! Thanks, Jim.
46
19,185
On the mk3 they come down the near side and finish behind the wheel arch under the side cover.
However, on the mk3 their far to thin and totally inadequate for UK requirements, my fitter used the *** lighter sockets wiring on the other side but that's only 10amp so still not good enough.
This apparently is all thanks to Fords German based specifications?! so in short, you'd be better off running your own decent wiring direct from the battery
Oct 28, 2006
1,060
Hi J+P why not supply the feed directly from the battery with two correct size fuseable links?Find out the current draw(amps),and devide it by 12(volts),the figure gained will be the correct size of cable needed in amps to safely do the job.
