- Jun 20, 2005
- 19,247
- 4,766
- 50,935
Marvellous, more problems🤬🤬.
New Visionplus tv booster working fine👏👏
But, Whale water inlet flap finally fractured. Not bad for 12 years. Luckily found a cream replacement flap for a fiver. However fitting is far from straight forward . The new flap can only be once the entire socket is removed. Needs careful removal and thorough cleaning and resealing with RV61. Whoever designs these plastic things to be so difficult to repair replace must have something missing upstairs!
Add to that the shower waste pipe is blocked. Will see what I can do tomorrow with some flexi probes and /or chemical drain pipe cleaner. Failing that it may have to be a new pipe. More lying on my back🤪🤪
