More help needed please ❤️
Hi 👋🏼 just wonder if anyone can shed light on this please?
Which was is on / off for my fridge / cooker / gas please? I know it’s trial and error but as I’m getting no joy I was trying to cut out the guess work xx
Also attached a picture of my external water outlet - I have an onboard tank but would like to fill from outside with an aqua roll - if possible. What do I need to fit the inlet shown pls?
Thanks everyone for your ongoing wisdom xxx
Normally when you turn a gas tap on the tap handle runs along the line of the pipe.
Sorry can't help on the water tank.
I concur with Dave regards the gas taps.
Without knowing the internal arrangements of the water system, I cannot tell you if you could use the lockable port as a water inlet.
Can you tell us what the model and year of the caravan is and the water system fitted which might help identify the way to deal with the port
