Am trying to fit a cutoff switch to my Reich motor mover,its never had one although I have never had a problem.The main cable which I need to cut is 10sq mm and I can only get uninsulated ring terminal with a 10mm dia hole.However when it was fitted they used insulated red crimps.This was in 2004 and now yellow is the maximum size (6 sq mm).Has anyone fitted their own mover,if so where did you source the crimps.If not I'll have to shrinkwrap the terminals after Ive crimped them.
