Mould on roof blind?
Aug 17, 2008
236
Just noticed that there is a small amount of what appears to be mould on one side/end of the roof blind.
Any ideas how to clean it in situ or this a removal to clean? If a removal then how do you get it out of the housing? Looks like a large Heki(sp) roof-light fitted to my Adria Adora
937
A bleach solution dabbed on with a sponge or something like Cillit Bang Black spot remover should remove it.
As working above your head mind you don't get any product in your eyes !!
644
We had small black dots on the inside of our roof blind,used a stiff brush which removed most of it then wiped it gently with a slightly damp sponge and it seemed to come off. Once it was dry I sprayed with one of those waterless car cleaners and wiped clean, not had any problems since, I put the black marks down to condensation.
Aug 17, 2008
236
Thanks, was thinking along those lines but it goes right to the roll itself so might be a job to pull it out far enough but will give those suggestions a try at the weekend when we've got a bit of daylight:)
