mpk rooflight
Sep 11, 2009
14
Having just come home from Sandringham pulled on the drive and to my horror found that the rooflight had parted company from the van.As the dome and handles have all gone i presume you can buy just that and not the whole unit,are they easy to fit?
Any help would be gratefully recieved...
Jan 31, 2010
105
its depends on whats left .if it is just the skylight this is easy .but it as damaged all of base part of it you may have to replaceall of it, on each side of the skylight inside there should be 2 small screws that hold the arms of the skylight in place check to see if these are you may be lucky and just replace the skylight these are around
936
Simon, the roof domes are held in place by small screws through the arms of th ehandles.
As long as the receiver on the main frame is in good condition and not snapped off, then th edome can be replaced very easily.
If the receiver is broken then a complete new roof light will be needed.
There are several sizes available , normally 200mm x 200mm, 400mm x 400mm are the ones most commonly used.
Have a look here: http://www.leisureshopdirect.com/caravan/ventilation/mpk_rooflights.aspx
If you check your van and see if just the dome can be replaced, if not and you want advice on replacing the whole fitting, just ask
Apr 7, 2008
4,909
You might as well buy a complete one, and if you can get away with leaving the base alone, you will have all the parts to repair it, but if something else has gone AWOL, you have the complete item there at hand to replace, here is a link to MPK Rooflight they dont look that expensive for a complete one....
Sproket.
Sep 11, 2009
14
Thank you for all your replies just been down to Lowdham caravans and brought a new dome with handles.As all the surround is intact its a breeze to fit,not a bad price either.
