Apr 20, 2025
Hey all, so we are about 6 months into caravaning and have a Adria Altea 542dk which has a mro of 1120 and MTPLM of 1300, but the van has a number of after market things so we have always been cautious to not put a lot in the van while towing. Today I got it weighed pretty empty (apart from hookup cable, wheel lock, water and waste bins) 1260!!!
How can I make the van lighter, I'm assuming motor mover must be 50kg, but the solar panel must be fairly light?
I'll weigh everything I had in the van over the weekend but I can't believe the shipping weight was as low as 1120
Apr 23, 2024
212
164
635
The spare wheel (17kg) can kept in the car whilst travelling and alko underbody wheel carrier (13kg) can IMO be thrown away, keep in safe place until selling the caravan.
Reactions: toad a caravan
Apr 20, 2025
The spare wheel wasn't in the caravan when weighing! And we don't have under body carrier either it's 2012 model so usually goes in the front
Unless you know something I don't I want to go look now
8,038
I had a French caravan which was stated to have ex works of 750kg and MTPLM of 1000kg. I weighed everything very carefully and trotted off to Brecon for a maiden voyage. Just outside of Brecon is a public weighbridge so I called in to have it weighed. Shock and horror it weighed nearly 1240kg. Spoilt the weekend I can say. Fortunately I had fitted new Kenda trailer specific tyres that were sufficient for the overload. When I got home I stripped out everything apart from one 6kg gas cylinder and the battery and took it to a 5 tonne weighbridge at Longleat. Sure enough it weighed in around 960kg, which left me 40 kg payload.
It transpired that the caravan was produced following the financial crash of 2008. The French maker had been updating the model with additional fittings, a stronger pop top roof etc. In some respects it was a hybrid. Plus the importer had added features attractive to British buyers, like heater, shower, hot water heater, fridge, mini cooker etc. The first owner had added an automated mover. All this had eaten into the payload, so I px’d the caravan, but in its defence it towed beautifully 😱
MRO s can vary by 3-5% which is not insignificant when you have low payloads. Don’t underestimate the solar panel weight measure it and try a find makers specification for weight details. Same with mover.
3,918
Sadly you are experiencing some of the realities of caravanning and how tight load margins can be.
This bit may be seen by some a rather contentious by some commenters here on PCF. For some unexplained reason caravans sold in the UK that have been accepted by the NCC often have a label by the entrance door that implies the caravan as a MTPLM which less than statutory MTPLM defined by the EU regulations. The EU MTPLM should be on a plate inside the front locker or attached to the AFrame. You may (or may not depending on the model of caravan) discover your real legal MTPLM is greater than you think.
Many UK manufacturers ( and I don't know about foreign makers) may be prepared to offer an MTPLM upgrade from the artificially low value to be closer or match the official value, and cant help feeling this is money for nothing as there is no mechanical change made to the caravan.
Dec 27, 2022
375
243
1,935
I have just had mine on the weighbridge, again, it was 1420kg, hitch was 82kg so pretty close to the 1500kg mtplm. This included bedding, cutlery, crockery, TV, hook up cable and water plus waste containers.
The rest, clothes, food, awning, chairs, and all the other paraphernalia we take travels in the car. Apart from clothes it's all packaged or in plastic boxes so easy to pack and unpack
I guess that if you have the room in the car you will be doing the same.
Its a shame that manufacturers don't use decent axle weights (mine is 1500kg) a 1750kg axle would make the van so much easier to use.
Just to add to keep the weight down I have a LifePo4 battery, 15kg saved, and Flogas lite gas bottle another 5kg saved.
Apr 20, 2025
The plate says 1300 so that's what I'll use. I have since realised there are other things hidden in the van I forgot to remove. Microwave, mini awning etc. so I'll be weighing everything this weekend and then probably removing the motor mover...it's 12 years old
848
Don't be misled into thinking that MIRO is the unladen or ex works weight of your caravan. It is not. It is the weight of the caravan that the manufacturer submitted for type approval, and that could have had a different spec. The actual weight could therefore differ by more than 3-5% from the stated MIRO. There was a case on another forum a little while ago where the ex works weight of somebody's caravan was more than 230kg heavier than the quoted MIRO because it had been specified with numerous factory fitted optional extras. I would say that was exceptional, but it does show what can happen.
1,967
669
Here's a thought for you. When you load the van to, say, about 1440kg when it has an MTPLM of 1450kg (which is usually the rating of the axle), what happens to the extra load when you/family/guests are sitting inside (during a rain storm.) The payload then would be way over the max axle load. I realise it makes no difference from a legal standpoint as it is static, but from an engineering view its a very different matter.
Dec 27, 2022
375
243
1,935
For me MIRO is some number that is totally irrelevant for day to day operations.
MTPLM is the only one that counts for anything.
Load stuff in the van, weigh it and add or subtract stuff until you have it right.
My first weighbridge venture was best part of 100kg over what it should be. The van weighed well over 1500kg plus the hitch weight.
When I finally sell the van and have emptied all my kit and kaboodle from it I will have one last visit to the weighbridge just to see how far away from the published MIRO the actual unladen weight is.
Dec 27, 2022
375
243
1,935
The extra weight is taken by the steadies 🤔
I'm confused by your comments, how can a 6 berth caravan only have a mro of 1120 and mtplm of 1300 giving only 180kg of capacity. One person is about 80kg so two adults and 4 kids would leave no room for anything else surely
848
When you are pitched the caravan is static. On the other hand, the MTPLM has to take dynamic conditions into account and instantaneous actual loads under dynamic condtions can be many times anything that may be encountered when static.
848
The NCC formula for payload provides 10 kg per berth, 10kg per metre body length plus 50kg to take cooking equipment, plates and leisure battery into account. On that basis, a 6 berth caravan with a declared payload of 180 kg would have a body length of 7m, which doesn't sound unrealistic. The actual weight of the persons in the caravan is irrelevant, as they don't travel inside the caravan while it's being towed.
639
290
1,135
I fitted anderson connectors to my Lifep04 so it only takes second to disconnect and transport in car. Switched to 2 smaller gas bottles, one of which is in roofbox.
Drain HW cylinder that is another 10-15kg saving for most van.
Previous owner replaced factory 5L 5kg HW cylinder with 20l 18kg(empty) one. The 250W solar panel and controller probably counts for 20kg .
I've isolation valves on HW cylinder as we rarely use so don't need to drain it every time. Also saves lot of time, thats quite while to prime water system if tank needs filling.
Apr 20, 2025
Ok so mtplm is only when towed and the engineers accept that the van will exceed mtplm when static.
Still don't get if I load a van up to 1300kg and the. We all live in the van with 4 people that could be 240 extra kg?
848
240kg extra is still a lot less than the maximum instantaneous dynamic load that the caravan will be subjected to while it's being towed. I wouldn't be surprised if the peak dynamic load would be in the order of 5000kg or even more if the road conditions are bad,
4,614
If it is a single axle motor weigh weight is about 32kg. If a twin axle about 60kgs. I would not get hung up on the sticker on the side of the body. There is a possibility that a previous owner may have downgraded the caravan MTPLM to suit the towing vehicle. Best it to get an AWS technician to check the maximum weight on the axle.
It is highly unlikely you could be prosecuted in the UK for exceeding the MTPLM value on the sticker on a 2012 caravan, but it is wise to check. Police will probably check the maximum load rating on the tyres or elsewhere, but maybe Mr Plod can give a better answer.
Apr 20, 2025
Learning something new everyday, so they only allow you to load it up to 1300 because the movement of the caravan while towing will force the load well above 1300kg? That's cool I always envisage my caravan falling apart with how bumpy UK roads are
3,918
You can thank you illustrious name sake -Sir Isaac Newton, for explaining the difference between static loads and dynamic loads. Think of it like a hammer driving a nail into some wood. If you just rest the hammer on the nail nothing happens, it only works when you give the hammer some speed before hitting the nail.
848
A caravan manufactured before the introduction of whole vehicle type approval is a bit of a grey area regarding MTPLM if there is nothing better than the sticker on the side to go by. Thereafter however, it’s not a plate on the axle that limits the MTPLM, but what is displayed on the statutory weight plate.
By the way, downplating a caravan subject to type approval is not as easy as it may seem. It can only be done with the manufacturer’s approval. Accepting a downplated limit that was not covered in the original type approval would probably involve more administrative effort than what it’s worth. Anyway, there is no point in downplating to suit the car‘s towing limit because it’s always the actual weight that counts and not the plated MTPLM. A car with a 1500kg towing limit can tow a trailer with a 2000kg MTPLM so long as it’s not loaded to over 1500kg.
Apr 23, 2024
212
164
635
Prof are you sure that if you leave the hammer on the nail for long enough it won't push the nail in ?😅. Seriously some manufacturers have been rejecting claims for 'failed axles' ( rubber inserts) on the grounds of 'Overloading' or 'Potholes' good job Fraser brown can refurbish such axles at a reasonable cost
848
I have a feeling that axles failing is an issue more as a result of poor quality of the material than actual overloading. For obvious reasons though, it would not be in the interest of the manufacturer to concede that as the potential cost to the manufacturer could be quite enormous. Besides, he always has the benefit of doubt on his side, as it is difficult for the caravan owner to prove beyond a shadow of doubt that the caravan was actually never overloaded to the extent that it could have caused damage to the axle.
848
When specifying a static weight limit such as 1300kg, the manufacturer will already have taken into account that peak dynamic loads will be well in excess of that value.
