Hello Buckman,
In your last post
Buckman said:
I never thought it was so difficult to get an simple straight answer to what I though was a a reasonable question. The question was never about the MTPLM.
Yet in you first post on this thread you stated
Buckman said:
If your caravan has a MTPLM of i.e. 1600kg and with a nose weight of 100kg, but actually weighs 1630kg when not connected to the car. If you then connected the caravan to the car, is the load on the caravan tyres then reduced by approximately 100kg resulting in the caravan being within its MTPLM?
I hasten to add that this is a scenario question as we are not over loaded and our nose weight is under 150kg.
This thread clearly IS a question about MTPLM, and that is why most of us have responded accordingly with simple straight answers!
For clarity, the MTPLM is accepted by the authorities as the MAM for trailer, and if a caravan when weighed exceeds its MTPLM it will be classed loaded above its legal limit.
The MTPLM does include the entire weight of the solo caravan and its nose load. It has nothing to do with the load transfer to the tow vehicle. Regardless of how much nose load you create by adjusting the position of the internal load, the MTPLM is a specified limit by the trailer manufacturer. On a concurrent thread the reason for manufacturers applying a lower MTPLM is explained.
The MTPLM is the total maximum permitted of the solo caravan, and as such includes the load on the axle in addition to the proportion of the weight applied to teh tow coupling.
Nose load transference is used when it relates to the towing ability of the tow vehicle. The tow vehicle has a maximum towed weight limit. The key word is "towed" in other words the load carried by the trailers wheels. This excludes the nose load which is carried by the car and not towed. However this is precisely dependant on how you have loaded the caravan.
But returning to you last post
Buckman said:
....I will make it even simpler. A caravan or trailer has a gross vehicle mass of 1600kg with a nose weight of 100kg on the hitch of the trailer. How much of that mass is transferred to the towing vehicle when hitching up? Maybe I never put across the original question correctly and subsequently confused every one into offering well meaning advice that had nothing to do with the question.
This is actually an entirely different question, but even here you are missing the important difference between weight limits and measured weights.
The Gross Vehicle Mass is the same as the MTPLM, and is a weight limit, not a measured weight.
So lets look at this in a slightly different way - from the tow vehicles point of view. What ever nose load you create (and don't forget this will change depending on how you load the caravan) the nose load is carried by the car not towed. The cars towed load is only the load actually carried by the trailers road wheels, and that value should not exceed the cars towed weight limit.
If we applied this to the figues you provided then of the 1600kg (Measured) weight of caravan with a 100kg nose load then 100kg would be carried and only 1500kg towed. But if of your 1600kg caravan you only had a nose load of 75kg, then 1525kg would be towed.
I am not going to spend time looking for the legislation you have asked be to provide, I suggest you look it up your self.
It is an EU requirement (Adopted by the UK) trailer manufactures must apply a data plate that includes the trailers Maximum Authorised Mass (MTPLM)
It is of course up to you if you choose to ignore this advice, and rather than simply repeating you dissension with the position we have suggested, perhaps you should provide the references that lead you to your contrary conclusions.
