MTPLM ?
Here's a technical question that I'm sure has been answered before but I wouldn't even know how to start looking for it. I'm hoping someone out there can give me the answer.
If the plate on the side of my van says for example MTPLM 1500kgs and I go to the weighbridge with it.
I drive onto the 'bridge with the complete outfit and that gets me the train weight.(Assume that this is within the vehicles limits)
I then drive forward and the bridge measures the weight of the caravan via the vans two wheels without disconnecting the van from the car and it states that the van weighs 1500kgs.
Heres the question. Am I overladen?
If I had disconnected the van from the car I assume that the noseweight of 80kgs would then be imposed on the weighbridge and would then have a caravan that weighs 1580kgs and therefore I would be overweight.
This is a serious question arising from a real situation and, if I have to lose 80kgs of load, I'm going to struggle.
Any authorititive answers WOULD be appreciated.
Aug 25, 2006
758
Unfortunately Del any weight imposed upon the towcar via the hitch has to be included in your MTPLM.
If you disconnected the van from the car the weight wouldn`t disappear, and it obviously wouldn`t be in the car, it would transmit to the weighbridge via the jockey wheel.
Does your MTPLM include anything that can be moved to the towcar, particularly awning, groundsheet, barbie etc? If you`re short of space in the car consider a roofbox, as long as yuo stay within the cars permissable weights.
And buy the beer when you arrive!
858
Yes, Angus is right. What you have measured, Del, is the towload, not the MTPLM. I'm afraid you'll have to put your caravan on a diet before you are legal again.
46
19,185
At least one leading European manufacture does not include the noseweight in their quoted figures, they say a van weighs xxxkg with a noseweight of xxkg but they don't combine them to give the overall van weight.
I tend to have some sympathy for this as it's the caravans safe maximum axle load 'while static' that's being talked about and the noseweight of a correctly loaded van is never going to add to it, it's either on the car or on the jockey wheel.
Where it will become a problem though is if your not aware of it and it takes you over your cars max tow limit or worse the gross train weight.
Aug 25, 2006
758
It becomes a problem when plod puts the van on a weighbridge and you`re 80kgs over your plated MTPLM.
I don`t think your argument would impress the officer, and certainly wouldn`t stand up in a court of law.
46
19,185
Not 'my' argument Angus, like I said, 'I have some sympathy'.
But MTPLM is not a 'plated' weight either and has no standing in law, however if the office does put the outfit over a weighbridge he can prosecute if your over the car manufactures max tow limit, more especially the GTW but still generally by more than 5% before he does.
On a weighbridge you weigh axle loads so in the case of max tow, it's still going to be debatable if noseweight is towed or part of the cars weight, it's certainly not going to show up on the caravans axle!
Aug 25, 2006
758
Sorry to disagree, Gary, but you only weigh axles on a dynamic weighbridge, if you are weighed on a normal, static weighbridge you can expect the outfit to be split, if the MTPLM is exceeded it is an absolute offence, just like speeding.
The 5% varience is discretionary, as I said the offence is absolute, and there is a train of thought (not mine) that suggests than towing a trailer in excess of its MTPLM is not only illegal but would invalidate any insurance.
The only way to accurately ascertain the weight of the trailer is to take it to a static weighbridge and weigh it solo. Anything else is a waste of time as it wont tell you its actual weight.
2,941
Gary, the MTPLM on the caravan's VIN plate IS a legally enforcable maximum weight - if you exceed it you're exceeding the caravan manufacturer's engineering design.
46
19,185
First I would totally agree with getting both the car and van weighed as neither the MIRO or stated kerbweight is likely to be accurate. This inaccuracy if your stopped by plod and weighed is not the best time to find out!
Problem I have with splitting the outfit on a weighbridge though, that's not how it was being towed on the road?
Below is a copied email reply from I believe a magazines 'legal Guru' posted elsewhere,(could be this mag although theres no way of knowing), It does however I think cover this overall problem very well;
This is my "get out of jail" card. With anything to do with the law we have to say that whilst we believe this to be the case, only the courts can decide.
Although the police do tend to use figures like MTPLM from the chassis plate, they shouldn't and I've had to point this out to them on a number of occasions.
In the "Everyman's guide to the Construction and Use Regulations" book the traffic cars are supposed to carry (loose leaf and usually with grey covers) it says that caravans (or more accurately trailers) are un-plated vehicles. That means caravans don't have to be fitted with a so-called chassis plate, and any information on that plate carries no legal status.
Interestingly MTPLM means nothing. There is one manufacturer who will, at the time of manufacture, fit a chassis plate with a higher MTPLM figure.
If the police want to issue even a verbal warning as to towing an excessive weight they must put the caravan on a weighbridge. Unfortunately they often don't know this.
All the advice I've had is that towing a weight in excess of the vehicle manufacturer's maximum is an offence.
However I would strongly advise you to check how much actual weight you intend to tow. The Caravan Industry's advice (as contained in the Towing Code which is Government recognised) is that for safe towing you shouldn't exceed 85% of the towing vehicle's kerbweight. The more you exceed that 85% guideline the greater the possibility of having an instability induced accident. Many traffic officers do know this and will issue a verbal warning if you do exceed 85%. Two years ago we even had a police force which was intending to prosecute a couple of caravanners for exceeding 85% and their solicitor advised them to plead guilty.
At the very least a traffic officer who believes you are towing an excessive weight, but may be legal, will take a close look at your caravan and towing vehicle to make sure they are absolutely legal.
What follows is a stock reply I send to readers who query the validity of the Towing Code and its advice about sticking to 85%. You may find it interesting.
The Towing Code
Over the last few years we, and I'm sure other magazines and the two clubs for caravanners, have been criticised for sticking to The Towing Code when advising people what weight of caravan they can safely tow. That criticism has even included letters and phone calls from caravan salesmen who have complained that we are loosing them sales.
I actually have some sympathy for the caravan trade. Imagine this scenario. A prospective customer goes to a caravan dealer hoping to buy a new four berth caravan. His car is the Ford Focus, Britain's best selling car and therefore the best selling family car.
If the salesman sticks to the Towing Code he finds, to his horror, that he hasn't got a new UK built family berth caravan light enough to be towed by Britain's best selling family car. To add to his frustration he sees Ford Focus cars towing caravans, but knows if he sticks to the Towing Code he won't be able to make a sale. Understandably he complains to those promoting the Towing Code for denying him a sale.
Because this is a fairly complex issue we've decided to produce this note which explains the situation.
History
Back in the late 1970's early 1980's the caravan industry was lobbying the Government to raise caravan speed limits. Nobody could disagree that a 50mph speed limit for caravans on motorways and 40mph on rural single carriageways was realistic when solo cars were being driven at 80mph on the 70mph restricted motorways.
The Civil Servants at the Home Office agreed to recommend a raise in speed limits, but only as part of a package deal. The caravan industry had to produce a code of good advice for their consumers. The resultant document was called The Towing Code. If caravanners followed it they could almost guarantee safe towing.
The Towing Code was signed by the National Caravan Council (NCC) on behalf of caravan manufacturers, importers and dealers, The Camping and Caravanning Club and The Caravan Club, the Caravan Writers' Guild and the Home Office on behalf of the police. There is some doubt as to whether the Society of Motor Manufacturers and Traders (SMMT) actually signed the document, but people who have been in the car trade for some time believe that in some way the SMMT did register their approval of the Towing Code as being best practice.
What the Code means
The Code is what, today, we would call Best Practice. The bit which really concerns us is the advice that the actual laden weight of the caravan shouldn't exceed 85% of the towing vehicle's kerbweight.
I've talked to two people who sat on the committee who drew up the code and their memories of what was said accords to what seems to me to be common sense. The more the 85% weight ratio was exceeded the greater the risk of instability and possibly an accident. However if the caravanner was experienced, loaded his caravan with care, recognised a potential road induced instability problem before discovering that it was a problem and used a suitable car (basically good power to weight ratio and fairly rigid suspension) exceeding the 85% limit a little bit shouldn't be a problem.
The legal position
The 85% guideline is not a legal requirement. However in recent years we've seen an increasing number of instances where individual police officers, and even two police forces, have believed that it was. Fortunately nobody seems to have had more than a verbal warning for exceeding 85%.
My own feeling is that if you wish to exceed the 85% guideline by any significant degree you need to be in a position to argue with a police officer that 85% is not a legal requirement.
However two legal towing limits are legally enforceable. It is an offence to exceed any maximum towing weight published by the vehicle manufacturer. It is also an offence if the combined weight of your loaded car and loaded caravan exceed the vehicle manufacturer's published Maximum Train Weight.
Slightly less clear is the position of caravanners who exceed any lower towing limit quoted by the vehicle manufacturer for a situation where the towing car is carrying more than just the driver. The legal advice we've been given is that exceeding this lower figure would be an offence. However the manufacturers who publish this lower figure (in particular Renault with their Scenic) seem to be very helpful in that they will send customers a letter effectively saying you can ignore this "driver only" lower towing figure. The legal advice we've had on this is that even if towing more may be an offence, the letter absolves the customer from having committed an offence.
Duty of Care
What has changed since the introduction of the Towing Code is the requirement of professionals and experts to exercise a Duty of Care towards the general public. This obligation is imposed on manufacturers, importers, dealers, individual salesmen and even caravan journalists.
So let us assume that you ask any of the above "can I tow that caravan with this car?" Unless we know a lot about you and are absolutely certain that you could be classified an experience caravanner with a suitable car we have no obligation but to advise you that your towing limits are those contained within the Towing Code. In other words 85%.
Lets assume the worst. We advise you that you can safely tow a caravan whose actual laden weight represents 89% of your car's kerbweight. You then have an accident and can either prove or imply that the reason why you had an accident was because the caravan was too heavy for your car. The Courts would then have absolutely no choice but to find that the person who gave you the advice failed to exercise Duty of Care and was therefore at least partly responsible for your accident.
Up to a year ago I would have suggested that even if I did tell you you could tow the 89% caravan mentioned above, the chances of me ending up in Court if you had an accident were so slim as to be non-existent. But the world is changing. Salesmen who tell customers they can just plug a new cooker into an existing outlet and ending up in Court when the mains circuit blows. In this modern society experts who give advice have no option but to err on the side of caution.
You've only got to look at current legislation to see how the legislature id determined to protect the consumer. You can still change a main's electrical socket in your house, but you can't wire in an extension socket or change a single outlet for a double unless you get the Council to inspect your work or you employ a skilled craftsman to do the job. In America, where much of this attitude comes from, there is even doubt about whether you can legally change the engine oil in your car.
The Towing Code is the industry's code of good practice and it would be a fool who would offer advice which was contra to what the Towing Code says.
The future
There is a good argument for suggesting that the Towing Code is out of date and needs changing. However it cannot be legally changed unless those who signed the original document agree to do so.
The real world
Confusion often arises when caravan salesmen, caravan journalists and even caravan manufacturers are seen towing caravans which are definitely over the 85% limit. Providing they don't exceed the maximum towing limit or the maximum train weight this is legally considered to be acceptable. As professionals or experts we are supposed to be aware of the risks and tow accordingly.
Very much "do as I say, not as I do."
3,922
Hello Del,
You have raised an interesting point, and sadly in my opinion I think you do have a problem.
Some basic Newtonian science:
It is important to grasp the difference between Mass and weight. You might have a 6Kg mass of steel. Here on earth it will weight 6Kgf (kilogram force), but take the steel to the moon and it will only weigh 1Kgf. The difference is due to the relative strengths of gravity on earth and on the moon. The moon's gravity is about 1/6th that of earth, hence the smaller attractive force on the same object.
Technically there is a gravitational force between all objects and it is broadly defined as:
(Mass1 x Mass2) divided by the square of distance between their centres.
Fortunately because us earthlings live on earth, and we use it as our gravity reference value, we deem that 1Kg mass will produce a weight of 1Kgf here on earth.
Most people forget to add the 'f' to the end of Kg when quoting weights.
The science bit over - now to your problem.
The MTPLM (Maximum Technically Permitted Laden Mass) of the caravan refers to the whole Mass of the caravan. It does not take into account how the mass is spread or shared between the various support mechanisms of the wheels and jockey wheel or tow hitch. It can be calculated by summing the total of weights supported by each of the main wheels and the jockey wheel when unhitched.
The logic behind this is that you could have a trailer that produces a 80 Kgf nose load, but without adding or subtracting any mass (items) to the trailer, but by simply rearranging them the nose load can be altered - any change in the nose load force will be reflected and balanced by load changes on the other points of support. - the overall MTPLM will not have changed.
Using your own figures, the summed forces are 1500Kgf on the main wheels + 80Kgf nose load which gives a total mass of 1580Kg.
If the Caravan is rated to an MTPLM of 1500Kg - you are overloaded - you need to shed some mass.
Some other points you should consider as you are so close to your limit. Some parts of the caravan are made of wood. As the moisture content changes so will the weight of the wood. Use one gas bottle rather than two. Don't load up with food and drink, purchase at your destination.
858
It is quite clear that the noseweight counts as part of the payload of the car. Hence, the MTPLM of the caravan is distributed between its own axle load and the all up weight of the car, not forgetting its effect on the car's axle loads, as well.
The 85% weight ratio of the Towing Code is a totally arbitrary figure. Absolutely no factual evidence has ever been produced that 80% or 90% would not have been just as appropriate. For this reason, it can only be considered a best practice figure but there is no point in taking it too seriously, neither by caravanners nor by the force of law.
3,922
Hello Gary,
Whilst I appreciate that you have only reprinted an article, I cannot agree with the interpretation that implies that the 85% figure can be used by the authorities to establish if an outfit is overloaded. It does not appear in the relevant legislation or regulations therefore it cannot be used as a definition of over loading on its own.
To add some further information to the point about the practice of some caravan manufacturers applying a lower MTPLM plate when a chassis can carry more:
The crucial issue is that the towing regulations use a trailer's MTPLM figure for determining the legality, rather than the actual mass of trailer and its load. The regulations look at the worst possible case. Bear in mind that these regulations apply to all type of trailers not just caravans.
So consider a box trailer MIRO 500Kg, and MTPLM 2000Kg (I have one just like this) Even empty I cannot tow this with my Saab 93 because it is only rated to tow 1600Kg I have to use my Renault Espace which is rated to 2000Kg
Now if the trailer manufacture were to re-plate the trailer to 1600Kg I can tow it with my Saab, but I could only legally load it to a maximum of 1600Kg.
The caravan manufactures actually do this on some models. They recognise that there is still sufficient pay load capacity with a reduced MTPLM plate to make it attractive to a wider range of customers who have limited towing capacities. They can therefore offer to up the MTPLM upon request for some models.
858
John, you seem to have something confused here. If your towcar is rated to tow 1600kg maximum then you can still tow a box trailer rated at 2000kg so long as its actual weight does not exceed 1600kg. It is only the driving licence regulations that refer to the need to be able to tow the maximum allowable weight, not just the actual weight.
Greeting again,
Can I thank all the contributers to this thread for their comments etc.
My question arose out of real circumstances but I had put the kitchen sink into the van to give a worst case senario. Having said that I had travelled home from a month away with not much less.
I have weighed the usual suspects Awning, Poles, Wife etc. (only joking!!!) and will have to do some further pruning. I suspected that the noseweight contributed to the MTPLM but was unsure.
Only good has come out of this discussion and once again thank you and Happy Christmas to all the readers
46
19,185
John,
I don't think he's saying that, just that some police forces are trying to? and as he says only cautions are handed out.
The police though, (what there are on the road now), are in a no win situation, the law/recommendations were designed around little boxes on wheels and a far cry from a modern caravan.
The whole of caravan regulations or recommendations need a thorougher overall
Take this van, it weighs 1500kg and 80kg either way is neither here nor there, 1500kN on earth is a lot of force to reckon with!
3,922
Hello Gary,
I have to disagree with you regarding a review of towing regs in relation to caravans.
A caravan is a type of trailer, and the regulations cover all types of trailer. To start to differentiate between types will cause no end of problems, and there will be some people who will try to pass of one type as another simply to get round regulations.
Keep it relatively simple.
There is no justification for any police force to warn or caution anyone who has not broken the law. They cannot and must not be allowed to caution simply because a caravan exceeds 85%. No law has been broken (unless the towing vehicle is not rated for that towed mass) They must have other due cause to caution or prosecute
3,922
Hello Lutz.
I am intrigued by your note.
I was informed by a knowledgeable trailer specialist that the towed vehicle must be rated to the MTPLM of the trailer, even if the trailer is not loaded beyond the vehicles limit.
I concede that I have not read up chapter and verse on this, and I will endeavour to do so, as it affects my choice of vehicle for my trailer.
It also removes one reason for manufactures to artificially keep rated MTPLM's low.
46
19,185
More than half of me agrees with you John, the less the better, but a caravan is a special case and far more now than when the 'towing code' (good as it still is) was thought up.
Take this question and your own, if as 'legal guru' says MTPLM has no standing in law then what are you worried about? particularly as the trailer load is obviously variable. As I see it, you won't be breaking a 'law' until you exceed the cars towing limit or the GTW.
At the other end of the scale, people have apparently been cautioned for towing at more than 85%? and this is only a recommendation! My point then about tightening up is valid because it appears no one knows including Plod where the law stops and good towing practice starts??
Beyond that though, yesterday on another forum a lady's first post was about buying a stolen caravan, she'd sold it on 3yrs later before Plod came knocking at her door!!
There are many more similar cases popping up on forums on a regular basis and this surely is the tip of the iceberg?
Overall then a caravan is very much a special case and should be treated very differently to a box trailer, preferable with it's own 'proper' registration documents plus number plate and some meaningful towing criteria so we all know where we stand!?
Never thought I'd hear my say it though!!!
Aug 25, 2006
758
I`m unable to see why a caravan should be a special case?
As regards a `police caution` for being in excess of 85%, if anyone is offered one they should refuse it and challenge it in a court of law if required.
It is not the law, and the police do not have the discretionary power to make it up as they go along.
The trailer load is not variable, as in a road tanker transporting liquid where the load IS mobile, the vehicle or semi-trailer is weighed in its static state (or over a dynamic weighhbridge).
If I was exceededing a MTPLM and got stopped, I would expect to be prosecuted.
Most HGVs have design weights for axles in excess of their plated weights, but this has no legal standing and wouldn`t be taken into account if overloaded.
Aug 25, 2006
758
Government take on it :-
Requirements regarding trailers used on the road are given in the Road Vehicles (Construction and Use) Regulations 1986, as amended and the Road Vehicles Lighting Regulations 1989, as amended. The following is a summary of the main requirements.
Weight
In the case of light trailers, that is less than 3500kg maximum laden weight, there is not any specified relationship in UK law between the weight of the towing vehicle and the weight of the trailer.
For M1 category vehicles (motor vehicles used for the carriage of passengers and comprising not more than eight seats in addition to the driver's seat) the maximum permissible trailer weight is quoted by the vehicle manufacturer. Alternatively, the vehicle manufacturer may provide a maximum gross train weight (the laden weight of the trailer plus the laden weight of the towing vehicle). If this is exceeded it is possible that the Courts or Insurance Companies may take the view that this constitutes a danger.
858
John, re your statement:
I don't agree with you on that one. Most people expect to be able to use a caravan at its rated MTPLM and would be disppointed if this were not the case. Also, many in the UK purchase a caravan based on observing the 85% max weight ratio. As this weight ratio is calculated using the MTPLM, this would put caravans with a higher MTPLM at a marketing disadvantage, especially when smaller towcars are involved.
858
Angus, although you are correct in your statement that Construction and Use Regulations do not specify any particular relationship between the weight of the towing vehicle and that of the trailer (at least not for the type of trailers we are talking about), the driving licence regulations certainly do. If the ratio exceeds 100% then you need a B+E driving licence (assuming you passed your test after the 1st January 1997).
Aug 25, 2006
758
Of course you`re correct, Lutz, but I never mentioned this as it was diversifying somewhat from the original question as posed,which never really brought the licence question into the arena.
However, as the age profile of caravanning seems to be reducing it will become inevitable that there will be more and more `youngsters` that may require the `new` B+E licence, and you are right to bring it to the attention of forum users.
With that in mind, i find it of concern that this doesn`t seem to be mentioned routinely in either car or caravan specifications or handbooks, and newbies may inadvertently find themselves towing illegally through ignorance, which in law is of course no excuse.
Aug 13, 2007
703
I was led to believe that a person that had passed the driving test after 1.1.97 only needed to take a towing test, if the train weight of the combined outfit exeeded 3.5 tonnes.
I see it that some one who passed the driving test this year can drive a vehicle weighing 2 tonnes gross & a trailer weighing 1.5 tonnes legaly.
G.
858
Here is the actual wording from the DVLA website (note the text in red):
Category B (without the +E extension)
Motor vehicles with a MAM not exceeding 3500kg having not more than eight passenger seats with a trailer up to 750kg. Combinations of towing vehicles in category B and a trailer, where the MAM of the combination does not exceed 3500kg and the MAM of the trailer does not exceed the unladen mass of the towing vehicle
