here
Maintenance Tips
Maintenance tips for your toilet
Maintenance tips for the flush-water tank
Maintenance tips for your refrigerator
The waste tank seal, the automatic pressure release vent seal and the cap seal must be cleaned regularly. When the toilet is being used frequently, monthly cleaning is generally sufficient.
We advise cleaning the seals and valve blade with Thetford Bathroom Cleaner.
Note! Never use household cleaners (bleach, solvents or other powerful cleaning agents). These may cause permanent damage to the seals and other toilet components.
For cleaning your toilet:
Squirt Thetford Bathroom Cleaner into the toilet bowl.
Flush the bowl with water and wipe down the rest of the toilet with a damp cloth.
Tip! For a really shining toilet, dry it with a soft dry cloth after cleaning.
Thoroughly clean the seals and valve blade, using Thetford Seal Lubricant and wipe them over with a cloth or a piece of toilet paper. Repeat the above operation if the seal and blade are dirty or if opening and closing the blade is difficult.
Note! Never use Vaseline or any vegetable oil. These may cause leakage.
When the toilet is not being used for a long period, it is advisable to clean the seals and then coat them lightly with Thetford Seal Lubricant. This will ensure that they remain in good condition (supple).
N.B. The valve blade seal is a part of the toilet that is subject to wear. Depending on the extent and manner of maintenance, after a certain period the seal will lose quality and must be replaced.
Back to top
For thorough cleaning of the flush-water tank of mobile toilets, we recommend our customers use ordinary Milton cleansing fluid.
Dose 50ml of Household bleach (Milton) cleansing fluid per 15 litres of flush water. Add directly into the flush-water tank and fill with clean water. Leave the solution in the tank for 24 - 48 hours, depending on the degree of contamination. Empty the tank by draining or flushing into an empty, clean waste holding tank. Rinse the flush-water and waste holding tanks thoroughly with clean water. Always empty the waste holding tank at a designated location. Do not use together with other products. Depending on the degree of contamination a second treatment may be required.
Note: Incorrect use or dosage could cause damage to seals and the level indicator. In case of doubt, reduce the dosage.
