my floating caravan!!
Nov 29, 2009
Hi There, I have just bought a vintage bluebird caravan. When I tow it the body floats slightly over the shassy at the end where the toe bar is, any ideas on what I need to do in order to solve this?? I am new to this so any advice will be well recieved thanks
Emily
Nov 5, 2006
805
High Emily. fraid I cannot help you with your van,but try this forum http://www.ukcampsite.co.uk/chatter/display_forum_topics.asp?ForumID=31
look specificaly for the "fixed it club" & "the Wizard" under "caravan repairs" I'm sure you will find help there for your problems
good luck TD
4,365
Hello Emily
You are right to worried. The caravan body should be securely fixed to trailer chassis, and no movement should be easily visible.
I suspect that something quite serious is amiss and I strongly suggest you get the caravan checked by a caravan expert.
Jul 1, 2009
2,142
is it a front box type if so it may be the box floating and not the caravan.if not it can only be the holding down bolts.
