Narrow caravan help
Dec 16, 2003
Hello,
We are considering purchasing our very first caravan, and have just discovered a slight problem.
We have a width retriction on our house and drive that means the caravan needs to be under 2.2m wide.
I understand that the max width is generally 2.3m, so i am looking for makes/models that are narrower than the norm.
We are looking for a 4/5 berth (if that helps).
Any help/advice would be greatly appreciated.
G
Guest
There are some narrower vans available, models from Gobur spring to mind. However, you may be pushing your luck to find a 4/5 berth tho'. I would suggest to start by buying one of the caravan magazines, they list most of the currently available vans at the back, and give the dimensions.
