Hi On the NE 190 Control Panel there are 3 buttons in a row on the panel.
Connect to Car battery, Connect to Van battery, Water pump switch
I could not get my "connect to Van battery" to work without a mains plug connection.
Reading in the manual it says: If the charger is not working and the van battery is not connected this system will not switch.
However I cannot help wondering why the "charger" must be working in order for this to work as simple logic tells you would only need van battery power for lights etc when you have no mains connection.
Are there any hidden 12v switches or fuses I should be checking for this to work.
Both the other switches work fine.
