NE190 Control Panel
Abbey Vogue & Swift Group are reporting serious faults with the NE190 and Battery Chargers. NE190 an be found as you walk in front door detailing pump, voltage etc. I have SER or E3 since new and no fault can be identified. Manual suggest an error between panel and fusebox.... Does anyone know what this means? Warranty runs out in 6 months and even Distributor is confused. Replaced battery charger recently as failed to charge, made no change to control panel.
Hi Fordbes, I would say there is a fault wth either the Control board, the data cable between the control and fuse board or the the board it's self, if your dealer can't sort it either contact http://sargentshop.co.uk/ or http://www.swift-talk.co.uk/
Thank you Metz. Swift Talk site is down and Sargent doesn't stock the NE190 or 5 pin cable however they put me in touch with a local supplier. Distributor has now changed their minds - three year parts warranty has now become two! Van is 2 years, 6 months old!!
