Nearly went Mad
Nov 4, 2020
149
53
635
So I had new tyres fitted and noticed it said never inflate above 40psi - I thought eh I’m around 60psi normally - on checking the tyres I noticed it said never inflate above 40psi to seat beads …. Then noticed the 65psi max inflate on the tyre - just something I saw - sounds daft but I thought I had wrong tyres on for a while - note to self look at the whole tyres -
  • Wow
2,561
Most tyre places seem to just inflate to full pressure straight away, but I have seen the odd on that inflates a bit, then bounce the wheel a couple of times to bed it in before a final inflation. Which seems sensible to me.
Perhaps that is what is meant.
Reactions: Baron Von Greenback
Nov 4, 2020
149
53
635
Yes it did John - just got myself in a tie as I towed to Loch Lomond last weekend and my true pal went up to 68psi I wanted to check the tyres on the side - they were filled to 60 psi as per the way of calculating the correct tyre psi - it went up by 8 psi -
2,561
Tyre pressure sensors will show a noticeable rise in pressure in use as the tyre warms up.
521
382
11,135
We've had pressure increases of up to 9psi when towing abroad in hot weather and at speed. Interestingly the side in shade has registered a degree or two lower than the sunny side!
Nov 4, 2020
149
53
635
The calc is max tyre pressure on the tyre /load index of tyre eg 65 psi/900kg x 1618 /2
so for me 65/900 x 1618/2 = 58.4psi
not what it says on tyre… this for single axle caravan btw
5,115
You correctly pointed out the tyre manufacturers spec. Most people haven’t a clue what goes on in the fitting bay. All tyre psi recommendations are cold. Of course tyres get hot. A hot pressure is pre calculated by the manufacturer. Never reduce pressure when the tyre is hot!
Oct 8, 2006
2,012
699
The max pressure embossed on the tyre sidewall is a US legal requirement and is not reflected in UK type approval.
