New caravan tv bracket required
Sep 21, 2011
We are about to purchase a new Elddis Crusader Aurora.
There is a TV and satellite point in the rear bedroom area on the wall between the bedroom and the bathroom.
How would members attach a TV bracket onto this partition wall?
Feb 3, 2008
3,790
How strong is the partition wall and how heavy is the TV you propose to use? This will determine the type of bracket, if one can be fitted at all.
Edit: Although not an Eldiss we use a removable bracket bolted to the side of an upright panel on the side of the mirrored recess, with 12v and aerial connection pre-fitted on the other side.
The arm and fittings came from our local caravan dealership, similar in design to this.
The TV is removed for travelling.
1,804
If the wall is very thin then the bracket may need additional support the other side. Not sure how practical that would be. I would not try it with a heavy TV and also check the instructions on the bracket.
The bracket fitted by the manufacturers to our caravan certainly has additional support behind for the plugs but not visible so I cannot be sure what it is.
