robf1234 said:hi i am thinking about another caravan i would like a one a bit longer 24 ft i have 21ft now ,,should i be looking for the wet heating ,,or stick to the hot air that i have now ,,thanks ,,
xtrailman said:....
Wet may be the better choice for winter caravanning as it controls the temperature a little better,.....
xtrailman said:But a 110AH battery fully charged in new condition although it will not give 1 amp for 110 hours, i would expect say 40 hours at a guess assuming no solar panel is fitted.
EH52ARH said:When I have had my Truma Combie running in our Coachman, once its up to the set temperature, We never notice the fan running, I suppose it must, but maybe just at a tickover, I have gone for two days with a 110 amp battery, but running the fridge and heating on gas, with no problems, but normally go to EHUs as wife needs to dry her hair using the hair dryer, rather than Kneel infront of the oven.
Raywood said:.............. I cannot see a fan uses very much power so it should not run down the battery but a solar panel should sort it if need be.
