New fish here......in deep waters!
Owner of Abi Ace Globetrotter 1992
Hello,
Little bit about myself.... I have been caravanning a lot back in my youth due to my parents being hooked, though apart from the odd static caravan holiday, not in my adult years so it's safe to say I know a little bit but not a lot.
We are having a new addition to our family and so I have been looking for a budget caravan (very budget) for cheap holidays. As caravans are generally quite an outlay, we had pretty much given up until a friend of our offered us a caravan for the price of a tyre...obviously I jumped at it.
There is a reason for this cheap caravan which is, it is riddled with damp. At this point I should mention that my profession is carpentry so I was aware of the work required.
A brief detail of the extent of damp.
The wall panels by the front widows are attached to framework which is attached to the outside skin, this is so rotten that the framework is pulling the outside skin in thus creating a large void where the windows close onto....lots of rain will get in there!
There are some water marks around some other rear windows though all the window seals are perished so this maybe just a seal replacement?
The shower tray has a split in it which isn't awful but can a repair be done?
The floor seems a little spongy though the span between the galvanised chassis underneath is substantial so I don't know if this is normal?
I am aware to make the caravan watertight is to remove all awning rails and reseal, new window seals and obviously to refix the framework to the front windows.
What I am aware of and the reason for this post, is this really worth repairing? I do not want to pay out more than what the caravan is worth, while also having to work hard repairing it. I am unsure of the construction and the cost of those parts.
What would you experienced caravanners do? If it's a repair, are there any cheap suppliers? I habe just found some window seal which equate to £200 for all the windows....already a large amount.
Lorne
Hello Lorne,
Welcome to the forum.and I am sure you will find lots of useful information if you ask and dig a bit.
1992 Van equates to 22 years old. Some caravans soldier on for 25 even 30 years if well looked after, so it may be worth repairing your own van, but What I cant tell you is how much it will cost or what it will be worth at the end of the repair.
In you favour are your skills as a carpenter, which is good because your caravan is essentially a wooden frame with skins attached. However the structural strength of the caravan is derived from the fact the skins are pinned to the frames which creates a stressed skin box construction. Another integral part of the strength is derived from some of the internal fittings, so don't be tempted to change the layout.
Only use rot proof treated wood to replace or rebuild, to avoid future problems. Just as in house construction, if you find a section of rot infested wood, you must make sure you remove all of the affected material to prevent re-infestation.
With regards the floor, it depends on its construction, but I would expect at 1992 it to be a foam sandwich. It may simply started to delaminate, in which case there are well known remedies. If its beam and board constructions then you will be well placed to decide the best course of action - Either way it makes sense to sort it so it doesn't niggle you latter on.
Search this forum for threads on delamination, and I pretty sure you can find kits at a number of caravan dealers if you need one.
Hi Lorne, welcome to the Forum and good luck with the DIY job on your caravan! There are lots of experienced caravanners on the Forum who will be pleased to advise you, I'm sure.
