- Nov 5, 2007
- 3
- 0
- 0
we have just acquired a caravan that needs a new headlining. Its beginning to hang down. Any ideas where we can get this from and any advice for replacing?
Thanks for your info.These are Polish caravans that have a cloth lining (I think the earliest ones used a `flock` type of covering).
To be honest I think the easiest thing to do would be to gently remove all the lot (cut around cupboards if you have to) and simply re-apply all the lot using a spray adhesive.
The vans have been imported under a number of names, but whether the spares back-up is good enough to supply a new insulating lining is something you would have to find out, but in view of the extremely low initial cost price of the van having a `professional` repair would probably be uneconomic.
Alternatively, if the loose patch is quite small I`d just inject some adhesive and stick it back on, just be careful what you use as you don`t want an adverse reaction to shell material(are they glass-fibre or an injection moulding?)and the beauty of a spray-type contact adhesive is that there aren`t liquids running about which may seep through the fabric and discolour.
Best of luck.
