I've just ordered some at the Bailey rate
I wonder if the same torque will be specified
Definitely, yes. It 's absolutely vital that you get reliable information of the correct torque to be applied or else you could do more harm than good. It would be wrong simply to assume that the same torque necessarily applies as for standard bolts.otherclive said:On an issue such as this it would be best to ask Bailey.
Lutz said:Definitely, yes. It 's absolutely vital that you get reliable information of the correct torque to be applied or else you could do more harm than good. It would be wrong simply to assume that the same torque necessarily applies as for standard bolts.otherclive said:On an issue such as this it would be best to ask Bailey.
WatsonJohnG said:Lutz said:Definitely, yes. It 's absolutely vital that you get reliable information of the correct torque to be applied or else you could do more harm than good. It would be wrong simply to assume that the same torque necessarily applies as for standard bolts.otherclive said:On an issue such as this it would be best to ask Bailey.
Hi Lutz
I will of course ask the dealer when I collect the bolts but expected someone on here to be already aware of the correct torque figure
Bailey did increase the setting I understand
Regards
Thanks MikeMike_S said:Have been in touch with Bailey again. The torque required for these bolts is 130Nm (this is higher than the Senator "original bolts" figure)
All I have to do now is get round to fitting them!
Mike
JTQ said:Having a background that has involved quite extensive design experience and in service checking of highly and fluctuating loaded bolting systems I am firmly of the view the underlyling problem here lays with the very short working length of the wheel bolts used.
To remain tight whilst accomodating inevitably settling of all the loaded surfaces the bolt needs to store energy in its elasticity and given a set diameter, material properties and preload the amount of energy stored is proportional to its length. These new bolts amongst other features greatly increase the working length that is streched, so they remain tight from the stored energy if the clamped or otherwise loaded surfaces yield a little.
They are a great technical improvement on the original bolts.
The evidence we have available may suggest what you say , but it is not a foregone conclusion.otherclive said:Given that these new bolts have a higher torque spec and they are lower friction shanks with rotating conical washers The clamping force has been increased significantly. So too low a clamping force was the reason some wheels came adrift........ Quel surprise! My xc70 has similar design of bolts with a torque setting of 140nm but they are larger wheels but I don't have to check them every time I go on a journey.
WatsonJohnG said:It makes me wonder about the design of the caravan brake drum as the depth of thread in the drum has an effect on the area clamped it would seem
When we lost our wheel the last half of the thread was ripped out of the hub as the bolts had loosened
The non spigot design also seems in need of attention I would have thought both from ease of mounting the wheel and security of fixing
Mike
WatsonJohnG said:My dealer now has the removal tools in stock but not the bolts as yet
I wonder if that means that they are all the same size and design
If so it would be wise to retain the existing security bolt I think even though they claim Prevents wheel theft
Sproket said:Hi John
Yes they did have the same tool![]()
Can't see why there should be a problem if you want to fit your security bolts as well as the new ones, just as long as they are all torqued to the same amount .....
Sorry for the delay I have only just found this.WatsonJohnG said:I hadn't considered the torque effect of using the improved bolts that have reduced friction and greater clamping alongside the older less efficient security bolts and as you say they should be OK
Perhaps JTQ could comment from his technical knowledge and appreciated input
Regards
