That is when i was working.We had a control system to keep the BOC supply of nitrogen with in our required limits, 18 to 20 bar, so the pressure certainly alters?
We took gas directly off the grid, which was then reduced to our required pressure.
The backup system came from liquid nitrogen tanks, then via controlled vaporizers gas was produced. output pressure was again controlled at 20 bar.
As i understand, normal air can leach through the tyre to atmosphere, while nitrogen doesn't, so pressure is maintained.
my local tyre dealer uses nitrogen on all new tyres free. I have to admit that over several years they appear to loose less pressure & may well give better performance. But..... surely after re-filling one tyre with air (say after a puncher)this tyre will respond more than the other side (still on nitrogen) to temperature induced pressure increase? This would, I think, result in the siuation whereby after a long run one side would have a significantly higher pressure that the other. Not a safe situation? But then again hardly any worse than having to use a (cost saver) 'space-saver' wheel!We had a control system to keep the BOC supply of nitrogen with in our required limits, 18 to 20 bar, so the pressure certainly alters?
