Newbie & Looking For Replacement Window
Hello all I'm a newbie to this forum, but have been caravanning for over 22-years now,
Currently have a Bailey Senator Wyoming 2005 and a BMW X5 tow vehicle.
Haven't renewed caravan unit for some years now as the kids (sorry young adults) are at that age now that they either will or won't go down the van,and as the unit is stored in Pembroke we only use it a few times a year now compared to every weekend with the CCC DA groups when they were little ones we've held back changing for the sake of it over the past few years.
We've have had about 6 vans and 5 towing vehicles over this period.
REPLACEMENT WINDOW PROBLEM
What i'm trying to source is a replacement offside kitchen window for the Senator Wyoming as the current one has delaminated and cracked not to concerned if it's a new or secondhand one (as long as it's in good overall condition that is) Anyway if anyone has a 2005 Wyoming could you poss. forward me a photo of the window in question along with it's external dimensions please as the wife didn't quite get it right when I asked her to get this info for me when she was down the caravan last week 🤔 🤔 (less said about it the better, needless to say it's warmer in Siberia in the dead of winter than in our house at the moment lol
look forward to hearing from one and all
Rich
Hi and Welcome! Try The Caravan Centre, Blaenavon. 01495 792700. The deliver by mail order worldwide, and break caravans of all years and models.
Try http://www.caravan-breakers.com/ this gives you a form to fill in with what you want and they check if they have it. For new windows try EECO but they are expensive.
And then pass the enquiry to people like the Caravan Centre!
True but it goes to rather more so it improves your chances of finding what you want.
Hi Rich
Premier Towing in the West Midlands have a good stock of second hand caravan windows and other spares.
http://www.premiertowingcentre.co.uk/breaking/3303912
They do mail order, you forward the size and colour of the window that you need
Hi Rich. Welcome! Just to encourage you, I have just sourced and replaced a window. There is a fairly good chance you will find one advertised by a caravan broker on ebay. Failing that if you post the window dimensions and your location them maybe someone on here might help.
What I learned - some windows are easy to remove and will unhook in situ just by opening them to their full extent (having removed any necessary window stays). Others need to slide off their rail, which usually involves drilling through a rivet or unscrewing a screw to remove the rail end cap, then if the bodywork permits it you can just slide it off. Others need the rail removing as there isn't enough clearance to slide them off without hitting something else. This is the worst case and obviously turns into a bigger job, you will need meths, white spirit, mastic tape or soudal fixall to refit the rail. Anyway, if you need a hand during the process just post, there are loads of helpful people on here. Best of luck finding one.
