Newbie saying hello and need advice
Dec 2, 2018
Hi all just bought a caravan but when I plug it in from house it trips house sockets even though nothing is turned on in van
1,819
Welcome to the forum. Not sure how old the caravan is so what it is equiped with might vary and it would help if you could give details of the age and model. Did you buy it from a dealer as if so you should be going back to them although it does help if you know what the exact problem is.
In most cases there should be a master a switch usually on a panel by the door. If this is off it cuts down the potential problems. If it is off then you are probably looking at the connection to the caravan, so check the hook up wire for damage and then open the plugs to make sure they are wired correctly. If that does not work then I think you may need the set up examined by an engineer.
If the master switch is on, or you do not have one, then I would remove each fuse in turn until you hopefully find which one is the problem. Once you know that it might be possible to take it further.
Dec 2, 2018
Thanks for reply turns out it wasn’t anything to do with caravan I’d plugged it into a socket in porch which has its own breaker on it... it’s there for lawnmowers and other outdoor things didn’t think it would be any different plugged it into socket in hallway all fine!!! Rookie mistake
Oct 12, 2013
3,037
A Woosie in the making ..... :p
4,788
Yes thats True Craig but you might loose your Knighthood if you don't get to a Woosie fest,
Oh and by the way welcome to the forum , Steverollo.
Oct 12, 2013
3,037
The chances of me getting to a fest are very slim , I got more chance of bumping into someone on a site so if you choose to de knighthood me so be it ! I'm still on the forum though ;)
4,788
Just teasing mate, but you must have a mishape soon to keep up your Woosie hood. :woohoo:
4,465
Plugin a properly wired caravan and EHU into ANY socket should not cause any house trip to operate. If it does so then it points to a problem in the EHU or caravan. DON'T IGNORE IT.
Get it checked out by an electrician before you attempt to use it.
Oct 12, 2013
3,037
So does it not trip when plugged into a different house socket ?
4,465
Perhaps the house needs the attention of an electrician also!
