Newbie
Jun 30, 2024
19
Hi all looking for some advice if possible I have a ruby baily 98yr.
My on board charger is pumping 10.2 volts to battery but doesn't seem to keep it charged.
Could it be my battery is to powerful or a fault
Thanks adam
4,464
Welcome Adam, I think you have a problem with the charger, it should be putting out about 13.5 volts , when you measure the volts at the battery terminals with a multi meter. Caravan voltage meters of that era were not very accurate.
Jun 30, 2024
19
I used a multimeter and only getting 10.2 v so that means a new charger then
Thank u for Ur help
Reactions: Mr Grumpy and Hutch
Oct 19, 2023
592
473
1,135
No but I think my battery is maybe to powerful it has 4 terminals on it so maybe I need a smaller battery what you think
4 terminals is a new one to me. Can you provide details of the battery (make, type etc) or post a photo of it?
Jun 30, 2024
19
Here is a photo of battery and circuit breaker that it connects to
I've just checked hand book it's says it can accommodate a 90ah battery but 40-50ah is recommended does that mean I need a smaller battery
8,880
No, as a battery charger is rated in output amps. A small charger output of say 5 amps will take longer to fully charge a 100 amp hr battery than it would a 70 amphr battery. I have used a 5 amp CTEK charger on 105 amphr batteries.
Jun 30, 2024
19
So would u say it's definitely the onboard charger is at fault as it's saying 10.2 on multimeter
8,880
Looks like it if you have charged the battery with the caravan unit, disconnected the battery terminals and then measured the battery voltage and it is still low.
5,117
Never come across a leisure battery with 4 terminal points as the majority only have 2 terminal, positive and negative? Maybe it is connected to the incorrect terminals? What is the make of the battery? A picture would be helpful?
Jun 30, 2024
19
5,117
A new one on me. States that the battery is specially designed and built for marine starting applications. Not sure if that makes any difference, but why not disconnect the terminals and test across them?
Jun 30, 2024
19
It's currently on charge but will be checking that before connecting back to caravan
