Newby question
Nov 9, 2021
We have a 2017 lunar solaris 674 with motor move on one axle
My question is can i fit movers to the other axle and just have one hand set
Jan 19, 2002
1,711
551
Might be worth checking out the specs of the fitted mover, as some models advertise for single/twin axle models and therefore must be up to the job! You could always give the company a ring for advice too.
Which Caravan Mover Is Best - Midland Motor Movers (Caravan Movers) has a comprehensive list of recommended models and their moving capacities and importantly whether for single or twin applications.
Hope this helps and welcome to the forum!
Nov 9, 2021
Thank you for the reply , will check them out
4,465
What is making you think you need a second mover?
Movers with 4 motors designed for TA's are not simply two SA movers coupled together. There's more to the working than that.
I would be wary about trying to fit another mover in addition to your first, as the combined current draw of the two movers would be very significant and could cause problems especially with an older battery or a smaller capacity battery.
5,504
You need to remove the other motor mover and replace it with the AWD motor mover for all 4 wheels. We did this and sold the old 4 year old motor mover on eBay for £450. Although it is possible to add the extra mover, the little bit of cost saving that you may achieve is not justified. In addition, if a fault occurs you have either two warranties or just the one that complicates things. Not worth the hassle.
We have a twin axle with AWD motor mover and have the extra drive on the other axle makes a very big difference especially on the continent. I would recommend going ahead and selling the current one and replacing it with a AWD as we found our single mover cumbersome in comparison to the AWD motor mover. You only need one remote.
