Thanks to my hand held LED 13 pin circuit tester I found that the supply to the caravan fridge on my new Sportage was not switching off when I switched the engine off. No problem folks, this is a new system. This Universal kit (AC09236050) is designed to be self switching at the pre-set voltage of approx 12,7 volts. So, when you switch the engine off the supply to the fridge remains alive until the towcar battery voltage drops to approx 12,7 volts. However I have found that I can force the supply to disconnect by briefly switching the Ign On then OFF again. This kit was supplied and fitted by my local KIA dealer
