Not surprising that it tilts up in the air as this will happen with most single axle caravans. Front weighs 80 kg and you probably weigh the same or similar so when you go to the back we have the Law of Physics kicking in. 🤣Thanks guys
I have taken back the Caravan with some other issues and they are looking into this problem and checking the nose weight gauge etc, also I forgot to say is that when I've loaded the caravan to 80kg and with all legs raised, if I walk towards the rear of the caravan it tilts up in the air!!
Not had THIS problem before, The new 2020 caravans ( as I understand it )have dampers fitted COULD this be problem?
thanks again
In the case of the 2010-2012 Hyundai Santa Fe, the noseweight is calculated as 4% of the maximum towing weight giving a discrepancy between the manual and automatic versions - Hyundai rectified this on the 2013-on model with both transmissions having the same noseweight limit.
I gave that advice based on my own practical experience with a 2011 Santa Fe automatic - rather than generalised comment about manufacturers' tests.
thanks again
Not the difference in kerbweight - it's the difference in towing weights between manual and automatic Hyundai Santa Fe's of that era - the auto is 2000 kg while the manual is 2500kg - Hyundai's policy at that time was to use the EU minimum of 4% for noseweight limit, giving 80 and 100 kg respectively.Going by your reasoning based on the 4%, the difference in kerbweight between the manual and the automatic would have to be 500kg, which is more than unlikely.
Your"practical experience" is hardly going to cover all eventualities. The manufacturer's limit is based on extended tests, both on the rig and on the road, taking into account adverse conditions which you may never have encountered. It is therefore wise to stick to the manufacturer's limit, bearing in mind that warranty coverage would be lost if the limit is exceeded.
Have you thought of getting the wheels balanced as that can make a difference to the actual towing?Thanks again guys as I said from the start the sintra is back with the place of purchase, When I get it back I will test the nose weight to see if it is the same as the scales etc. and will let you all know the out come of what they have found,
I do realize that when i walk back in the caravan the weight will transfer and tilt by my Verona didn't !! as for the dampers they are fitted as standard I was just concerned that they are an added thing that might be wrong! talk to you all next week
Kind regards
Without knowing how heavy you are, that might indicate a low noseweight - if it's actually 80kg you'd need to be about 100 kg to balance that right at the rear of the caravan as the A-frame gives extra leverage to the noseweight.Thanks again guys as I said from the start the sintra is back with the place of purchase, When I get it back I will test the nose weight to see if it is the same as the scales etc. and will let you all know the out come of what they have found,
Kind regards
It's not a serious error, about 5%, so just a few kg.Do not use he jockey wheel to check the nose weight as it will give you a false reading as it is not as far from the axle as the hitch.. The weight is taken at the hitch. You need a length of wood cut to the length needed to measure at the tow hitch level in the hitch to get the correct reading.
ALKO do make a jockey wheel that will weigh the nose weight, but you need to take measurements before using it and then use a chart to correct the figure on the jockey wheel. Depending on the measurements the figure at the jockey wheel can be seriously out.
The gauge was tested by either the magazines or one of the clubs some time ago. The problem is that the accuracy at the jockey wheel depends on the distance from the axle and to the hitch. The weights needed quite a bit of recalculation with a longer caravan, so on that basis I would not use the jockey wheel as it can be more than a couple of kilos out. The difference should not be enough to affect the handling in most cases but it might leave you with an illegal outfit.
I would guess that the offence that would be used by a police force would be related to a "dangerous load" etcActually, as the distance from the coupling to the jockey wheel is more or less constant regardless of the length of the caravan, any inaccuracy of a jockey wheel noseweight gauge will be less for a long caravan than for a short one.
Besides, exceeding the noseweight limit is not an offence as such. It only a matter of product liability. It would only be an offence if it also leads to the rear axle load of the towing vehicle being exceeded, as well.
