Nose weights - Santa Fe
I know this has been covered several times on this forum and Lutz has also added his technical expertise but I am still confused.
Santa Fe has only 80kg nose weight allowance for the auto but much higher for manual. Lutz has indicated this is due to structural constraints but what does this mean ?
I understand max. towing weights being different from auto to manual but can't get my head around the reason for nose weight differences.
Can someone explain ?
James, this question never seems to be answered. I contacted Hyundai and received a brief reply from it's Homologation Department. The reply was "4% is the ratio used between trailer weight and nose load and so as the trailer weight for the Santa Fe is 2500kg for the manual and 2000kg for the auto the nose load equates to :
4% of 2000kg (auto) = 80kg
4% of 2500kg (manual) = 100kg"
Hyundai has obviously used this method to calculate nose weight on previous models eg my '57 manual has a trailer weight of 2200kg and using the 4% figure gives a value of 88kg which is what is stated in the handbook. Not sure where this leads apart from the heavier the maximum trailer weight the higher the nose weight limit irrespective of any structural / suspension considerations.
Mar 10, 2006
3,274
47
That's interesting, obviously Nissan don't use 4%, my xtrail, max tow 2200kg, comes with 100kg nose limit.
Dare i say i would be tempted to ignore the 80kg and load up to 100kg.
Jun 14, 2009
357
I'm with you on this one Ray. I have an auto santa Fee. It has the same rear suspension and rear axle as the manual, so can not see why there is a difference in nose weights. I have the workshop manual on cd, the rear springs and dampers are the same, except for the 7 seater which has self levelling dampers.
936
I must say that the reply from Hyundai does them no credit. Normally, the manufacturers carry out durability tests on a shaker rig and gradually increase the noseweight until cracks appear in the underbody sheet metal. The limit will then be set at a level just short of this. To simply specify noseweight on the basis of a 4% formula is rather unprofessional on the part of their engineers.
Lutz
This is what is confusing me. If as you say these durability tests are made until some failure occurs and then the manufacturers then take a nose weight figure just below this why is the manual nose weight different from the auto. Surely the body construction is the same for both models ?
Whilst you disagree with the manufacturers taking 4% of the towing weight at least it does give some reason to the differences in nose weight.
936
Yes, the 4% does explain why they specify a lower noseweight for the automatic than the manual, but it is a very poor explanation. As you say, the body construction is unlikely to be any different, so theoretically the noseweights should be the same, even if the towload limits are different.
Jul 9, 2001
734
4% is the legal minimum for noseweight. Are the figures the same for the new Kia Sorento?
However I would not recommend exceeding 80kg on the auto as you would then be towing illegally.
Nose weights same for new Sorento.
It does make me wonder if both the towing limits and nose weight figures have much technically verified data behind them. Are manufacturers using different criteria to establish these figures or what?
936
From the reply John got from Hyundai, I would say that they are an exception.
I would love to know the calculations that are carried out by manufacturers. It is in their interests that any 4x4 can tow well so you would expect this to be an important part of the design. They would make the body construction so as to take fairly high nose weights (you would expect) in a similar vain they produce even more powerful diesel engines with loads of torque (new Santa Fe and Sorento over 200 BHP), which can obviously tow well. So the starting point must be what percentage of the kerb weight do they allow as a max. towing weight. What I find a bit strange that they seem to get very round up figures for max.towing weights such as 2500kg for manual and 2000kg for auto
For Hyundi and Kia this is quite important to get right because we have already seen many people on this forum say they would be ataying with the old Sorento because the new model does not have the towing capabilities of the old one.
I know the Santa Fe and new Sorento are quite different from the old Sorento models but you would expect towing to be a fairly key aspect in the design.
936
Towload limits are normally determined by test, just like noseweight. I suspect that towing ability does not feature as a major priority in the design of most cars, other than true 4x4's, as a high towload obviously requires appropriate measures which inevitably cost money. It is doubtful whether a manufacturer would allow a product cost increase simply to satisfy those who wish to tow as the vast majority do not and they would not be prepared to pay the premium. Having said that, true 4x4's, being strong enough for off road use anyway, normally have towload limits well in excess of 100% of their kerbweight. On the other hand, SUV's which are not designed for serious off road use, are not subjected to such high loads except when towing, so the manufacturers are probably unwilling to make their designs suitable to tow heavier trailers.
4,398
Just to add, If manufacturers were designing vehicles for towing, at the very least the towing bracket would be built in and not an add on as it is with all domestic cars that I know of.
Jul 15, 2008
3,920
1,105
I reproduce the following and give the source as The Camping & Caravanning Club....
It shows that ' a manufacturer's towing limit' does not mean what most people think it does and its method of calculation can vary to such an extent as to make comparisons meaningless!
"The manufacturer's towing limit is not set by issues of stability, simply by the car's physical capability.
In an ideal world, with perfectly surfaced roads, no crosswinds, air turbulence from speeding HGVs etc, then this limit could be used for matching purposes.
What the towing limit does give is an indication of the pulling power of the car.
Ideally, the weight of caravan should be below the towing limit by a reasonable margin - and more so when using an automatic car.
Trainweight or gross trainweight (GTW) is the maximum weight that a vehicle can move on the road, as stated by the manufacturer. This is the combined weight of vehicle and any trailer being towed and is the largest figure shown on the vehicle's VIN plate, which is usually found under the bonnet of the car.
The trainweight check is needed because the way the towing limit is set by manufacturers varies. Normally, the limit is set as the maximum weight of trailer that can be pulled away from a standing start on a 1 in 8 (12 per cent) gradient. Sometimes this limit is set when the car is fully loaded. Other times, depending on manufacturer or even model, the limit will be set with only a driver in the car or with a set number of passengers, but less than the full loading.
If you subtract the gross vehicle weight (the first figure on the VIN plate) from the trainweight (the second figure on the plate) you get the legal weight limit of trailer you can tow when the car is fully loaded. Hence, if the manufacturer has stated the towing limit when only the driver is present, then the subtraction from the VIN plate will give a much lower figure for the fully laden condition, but which is closer to the situation when the car is transporting the family and luggage.
When the manufacturer has stated the towing limit at the condition when the car is fully loaded, then the limit derived from the trainweight usually coincides with this stated towing limit".
936
If the specified gross train weight is less than the sum of the gross vehicle weight and the towload limit, then this is an indication that the gross train weight is determined by braking performance rather than pulling power.
chenzhen
BANNED
May 19, 2016
99
"The word vintage, used to describe dresses and clothing, is a broad term that is generally used to refer to clothing that originates from a past era. In general, clothing that dates earlier than the 1920s, is considered to be antique. Whereas clothing and dresses that have emerged after the 1920s, up to the 1980s and 90s, is considered to be vintage. Retro, or vintage style, usually refers to clothing that is an imitation of the style of a previous era.
A range of vintage style clothing that is hugely popular today, are the fifties dresses. The enduring popularity of these dresses, might be because that was the time women's clothing made significant strides, as it was after the second World War and many restrictions had been lifted and designers had more freedom and materials available to create beautiful women's fashion ranges.
Some of the popular dress styles that have enjoyed a timeless appeal have included the Ophelia dress, floral tea dresses, Audrey Hepburn style dresses, the figure hugging Lindy Bop dresses and dresses made famous by Grace Kelly and many classic Hollywood stars. Even today, young women are choosing vintage style dresses for their special occasions such as a ball, prom night, and other formal parties, because they have a definite charm and elegance and have been designed to enhance a woman's shape and beauty."
fake oakleys
michael kors uk
cheap ray bans
rolex watches for sale
nike free flyknit 5.0
ugg boots
coach outlet online
yeezy boost 350 white
michael kors bags
air max 90 white
ralph lauren outlet
louis vuitton bags
converse sale
coach factory outlet
adidas shoes
nike free flyknit 3.0
burberry outlet
nike air force
cheap ray-ban sunglasses outlet
tory burch shoes
nike tn pas cher
chaussure louboutin
adidas nmd runner
louis vuitton handbags
skechers outlet
oakley sunglasses cheap
cheap jordan shoes
ray bans
adidas nmd black
reebok classic
adidas trainers
vans store
nike cortez white
pandora charms
air max 90
adidas shoes
fitflops shoes
timberland uk
pandora charms uk
armani exchange
burberry bags
under armour
louis vuitton outlet stores
oakley sunglasses wholesale
pandora jewelry outlet
cheap basketball shoes
ferragamo
ralph lauren
pandora rings
toms outlet
michael kors outlet online
prada sunglasses wholesale
cheap ray bans
www.coachfactory.com
cheap air jordans
michael kors handbags
valentino
michael kors outlet clearance
michael kors outlet
ugg boots
ralph lauren
ghd
mizuno running shoes
nike air force black
cheap jordans
nike free run flyknit
cheap ray bans
sac longchamp
kate spade outlet
cheap ray ban outlet
ray bans
true religion jeans
babyliss hair dryer
michael kors bags
true religion outlet
reebok outlet store
ray bans
nike trainers
polo outlet
fitflops
adidas superstars
true religion outlet store
kate spade uk
discount nike air max
ray ban sunglasses outlet
jordan pas cher
levis 511
nike huarache
omega speedmaster
christian louboutin uk
michael kors outlet store
tiffany jewelry outlet
polo ralph lauren men
adidas supercolor pink
rolex replica watches
ray ban outlet store online
cheap nike air max
coach outlet store online clearances
tory burch flats
hollister hoodies
nike cortez shoes
louis vuitton outlet online
hollister hoodies
pandora jewelry
louboutin outlet
coach factory outlet online
adidas pure boost black
designer handbags wholesale
yeezy boost 750
true religion
kate spade outlet online
tiffany uk
lebron james shoes 12
red bottoms outlet online
cheap jordan shoes
jordans
gucci borse
gucci handbags outlet
ray ban sunglasses sale
lacoste shoes
bottega veneta shoes
michale kors uk
ray ban sunglasses discount
louis vuitton uk
cheap ray ban sunglasses
longchamp outlet
micahel kors
adidas superstar white
air max
cheap nfl jerseys
burberry outlet
christian louboutin outlet
hollister clothing store
oakley sunglasses outlet
ralph lauren
nike blazer
michael kors canada
birkenstock sale
cheap ray bans
white converse
louboutin pas cher
jimmy choo
ed hardy uk
bottega veneta sale
north face outlet
nike air max 95
burberry sale
abercrombie and fitch outlet
hollister kids
louis vuitton purse
supra outlet
nike huarache black
nmd adidas
asics running shoes
lacoste polo shirts
jordan shoes
michael kors canada
abercrombie & fitch
coach outlet online
tiffany jewelry
burberry outlet canada
ray ban sunglass,ray ban sunglasses,ray ban outlet,cheap ray bans,cheap ray ban sunglasses,cheap ray bans,ray bans
ralph lauren outlet online
canada goose outlet
mlb jerseys wholesale
vans outlet store
birkenstock sale
coach purses on sale
ferragamo outlet
valentino bags
rolex submariner
mont blanc outlet
hollister co
nike air force
the north face outlet
armani outlet
tiffany and co outlet
michael kors handbgas
cheap oakleys
north face jackets
dior sunglasses 2016
coach outlet online
north face uk
kate spade bags
polo ralph lauren outlet
ray ban outlet online
adidas nmd uk
ghd hair dryer
jordan shoes
hollister uk
michael kors uk
buy red bottoms
nike roshe run
kate spade outlet
toms shoes
cheap oakleys
louis vuitton factory outlet
polo ralph lauren outlet online
puma outlet
true religion uk
chi flat iron
fitflops sale clearance
true religion jeans outlet
michael kors outlet canada
michael kors outlet
oakley sunglasses
instyler max
true religion jeans
fitflops
fitflops shoes
polo ralph lauren
pandora sale
michael kors outlet stores
hermes outlet
cheap oakley sunglasses
nhl jerseys wholesale
toms outlet
longchamp uk
timberland shoes
asics gel kayano
michael kors outlet
ed hardy
polo ralph lauren
versace sunglasses wholesale
louis vuitton borse
kate spade handbags
new balance shoes
versace sunglasses
birkenstock outlet
oakley sunglasses,oakley sunglass,cheap oakley sunglasses,oakley sunglasses cheap,oakley sunglasses outlet,oakley store,oakley outlet,oakley outlet store,oakley sunglasses sale,oakley sunglasses discount
michael kors bags
birkenstocks
nike air max 90
timberland boots for men
kobe bryant shoes
adidas shoes
birkenstock shoes
christian louboutin shoes
under armour outlet store
rolex daytona
michael kors outlet
abercrombie outlet
birkenstock uk
cartier
omega
polo ralph lauren
true religion sale
burberry outlet stores
nike shoes for cheap
nike store uk
sac longchamp pliage
nike force 1
ecco outlet
coach outlet online
louboutin shoes
canada goose jackets
nike free runs
reebok
converse outlet
coach outlet online
stephen curry basketball shoes
hollister kids
jimmy choo outlet store
nike air max 90
hermes belt
louboutin shoes
supra store
stan smith adidas
toms outlet
rolex watches uk
wholesale nike shoes
gucci outlet online
yeezy boost 350
nike free 5.0
cheap nfl jerseys
reebok shoes
coach outlet online
coach outlet store
tiffany and co jewelry
timberland shoes
ray ban outlet
timberland boots on sale
cartier love ring
white converse
louis vuitton purse
air max 90
ralph lauren pas cher
air jordan shoes
prada handbags
michael kors canada
holliste sale
adidas gazelle
nike flyknit racer
oakley sunglasses uk
yeezy boost 350 balck
lebron james shoes 2016
ralph lauren outlet
nike running shoes
kobe 11
nba jerseys wholesale
coach outlet store
michael kors handbags outlet
hollister clothing
louis vuitton pas cher
ralph lauren sale clearance
cheap oakley sunglasses outlet
"One of the most popular, but simple fifties dresses, is the petticoat. This was designed to be flattering to a lady's shape and also, to enhance the dress she was wearing over it. Petticoats made of silk and woollen materials were initially introduced for women to wear under the main dress, as they provided warmth and would enhance women's busts. The classic petticoat then became shorter and lacy petticoats became the fashion, as they delicately accentuated the dresses that were worn over them, such as the Ophelia dress.
Vintage style dresses UK are available in a wide variety of sizes from vintage clothing shops, textile fairs, auctions, flea markets, estate sales, antique markets, garage sales and collectable fairs. However, there is always the risk with buying genuine vintage clothing, that the sizes may not match current clothing sizes. But there are a number of special boutiques online, who specialise in designing and creating vintage clothing to order. They can take your specific measurements and produce an outfit that will be tailor made and fit you perfectly"
d;lhf
