Nosewieght - brakes on or off?
Sep 17, 2007
7
Just got our new van and are having a problem getting the noseweight correct. I have a guage ( the one with the red top) and it states clearly that the handbrake should be appied. I seem to remenber someone saying that the handbrake should be off and wheels chocked. As I am getting different readings on and off, which is correct?
4,372
Hello Alan,
I am of the view that the wheels should be chocked and the hand brake should be off.
My reason for adopting this view is; that caravan must be free to rotate on its axle. If it is restricted through the action of the brakes, it will affect the force created at the tow hitch.
The effect may either increase of decrease the apparent nose load, depending on which way the caravan was moving when the brakes were applied.
In reality the effect may not very large, but it could make the difference between being legal of not.
It is only fair to point out that there are other factors that will also affect the nose load, so it is important to keep things as consistent and repeatable as possible.
The caravan must be on level ground, the tow hitch must be at the same height as when it is attached to the car and the load must be transferred through a vertical pole.
Can't disagree with JohnL but I always leave the brake on as I have to check on a slope but with the van level and I find that I can raise/lower the van by hand(s) when on the gauge so that it finds the level .
I have doubts as to the precise accuracy of the gauges and feel that they are only giving an idea approx noseweight anyway so any affect on accuracy with/without the brakes is marginal
This is what C & CC say
With the caravan
brake fully on and the
steadies raised, lower
the coupling on to the
bathroom scales using
the broom handle.
As soon as the
jockey wheel lifts free
from the ground read
the weight off the
scales. Make sure that
the caravan is level
while taking the
reading.
If you don't know
what the noseweight
of your caravan should
be then as a guide
ensure it doesn't
exceed seven per cent
of the actual laden
weight of the caravan.
Adjusting the
position of items
inside on either side of
the axle will help you
achieve the ideal
noseweight.
Generally speaking,
the higher the
noseweight, without
exceeding the car and
caravan's limit, the
more stable your unit
will
931
Although theoretically having the brakes on could affect the noseweight reading due to resistance to movement, this movement is so small that it would easily be taken up by compliance in the axle and the tyres. Any effect on noseweight would therefore be negligible. It's easy enough to verify for yourself by trying both conditions (brakes on/off).
Sep 17, 2007
7
Hello
Thanks for your advice, I have had a thought that as we don't travel with the handbrake on, then surely the real weight must be as in a travelling condition. I am on a flat surface and the height of the hitch is as close as I can get to the same as my towball, I have to trust that the guage is accurate, I may test it against the bathroom scales I havn't had another chance to check and I need a new bottle of gas so will try again with a full gas load.
Alan
