• We are currently experiencing delays with our email service, which may affect logins and notifications. We sincerely apologize for the inconvenience and appreciate your patience while we work to resolve the issue.
On Board Tanks
Jun 24, 2005
704
18,885
I realise that this is a subject that causes a lot of discussion but, personally, I find an onboard tank indispensible. Given that the new Bailey Unicorn 2 does not have one ( IMHO a very backward step) have any members fitted a tank (to any 'van) and, if so, at what cost. Was it practical?
40
I am not a great fan of fitted on-board tanks; experience with a previous caravan was that the tank was difficult to clean and the fitted submersible pump prone to airlocking. Also, it avoided having to empty the tank before towing as 50 litres = 50 kilos and the tank was quite a long way forward. Later vans have the tanks right at the front which makes matters much worse. it is also pretty antisocial to empty a water tank onto a pitch when leaving.
However, I have fitted small 'tanks' to more recent caravans to provide sufficient supply for travelling, particularly in winter when going to Spain. I use a 20 litre plastic 'jerry' can from CAK Tanks which has a filling hole sufficiently large to take a submersible pump and which is easy to fill in situ either pouring carefully or using a funnel. This is fitted in the bed box close to the usual water inlet. A Whale pump socket is fitted nearby, with the electircal supply taken in parallel from the existing socket but with an on/off switch included. The pump outlet is connected to the incoming cold water supply with a tee piece and a full bore 90degree turn isolation valve.
To use the on-board, simply turn on the valve and switch and the onboard pump will run when taps are opened. Whale sockets have a built-in non return valve, so the isolation valve may notbe strictly necessary, but since any leakage when using the external ppump would be into the bedbox I play safe.
Mount the tank as near the axle as possible. You can tow with the pump installed and the tank about half to two thirds full without sloshing any water out, or with more water if you remove the pump and replace the plastic top. Another reat advantage is that you can remove the entire 'tank' easily for cleaning.
Aug 24, 2012
300
Our caravan has a large inboard tank at the rear, it has a large access lid so you can get to the pump and it's easy too clean out the tank through the access hole if you want. We regularly put a cork in the tanks over flow pipe and top the tank up to the lid brim and let it stand with Puriclean. No cleaning issues at all. As for emptying the tank, the outlets underneath the van accepts a hose and you can water the pitch's border plants or run the water where you want
. No need too be "antisocial".
I've fitted a couple of tanks to caravans, four self build motohomes and a VW surfer van. First point of call is always www.caktanks.com who have always given good advice. Bailey and Swift also provided advice on where to drill the side of the caravans for the filler points.
If you're self fitting, in most cases it makes sense to make the fixing easily removeable. Caravan manufacturers pipe work is not always the smartest layout, our inboard tank can now fill automatically from the Aquarolls. The standard setup would leave the inboard pump whirring away when low
until you switched to outboard tank.
Jun 24, 2005
704
18,885
I usually, on a long trip, tow with about 10ltrs of water in the tank. If I drain the tank completely, I get onto the site road, *** into the 'van and open the valves on the hot water tank (saves scorching the grass) and the onboard tank. The system on my present Senator doesn't utilise a funnel or submersible pump. I just have to fill the Aquaroll, connect it up, fill the onboard tank then refill the Aquaroll - that's it. The changeover from the Aquaroll to the onboard is done at the flick of a switch. The onboard tank has a large aperture in the top for cleaning (although I usually just use a sterilising fluid).
This is the system I will try and replicate on the new van and will certainly visit the caktanks site for advice. It occurs to me that the front storage space on the Unicorn 2 would be an ideal place for a tank (provided that I can get one to fit though the access doors).
Aug 24, 2012
300
Surely there is some way of accessing the storage space underneath the seat cushion rather than through the access doors?
I can't believe that Bailey have fully sealed down the top of the storage that the cushions sit on
CAK have offered good advice over the phone, do give them a call if you need specific help.
Jun 24, 2005
704
18,885
I stand to be corrected but, as far as I'm aware, the front storage area cannot be accessed from inside the 'van.
I have been fitting my own tanks for 20 years now to different vans
Fiamma have a range of tanks as do C A K tanks previously mentioned
I fit 12V contacts in the existing caravan water inlet and divert the pipe from it to fill the tank via a new submersible pump in the aquaroll
A pipe from the tank then goes to the inlet of the onboard pump to supply the taps
There is a low level warning light and tank fill switch to the submersible pump which has a pump timer switch to cut out when the aquaroll is almost empty
I always travel with just enough water in the tank to extinguish the low level light
The tank is in one of the front bed lockers
Hope that helps
Aug 21, 2010
Hi Fellas. I wouldn't be without underfloor tanks. We have 2 x 80 litre fresh and 1 x 180 litre grey with 20 litre Thetford cassette toilet. Is good for around 4 days freedom camping including showers. Trick with weight balance is to have grey water tank above axle centres and between the fresh tanks so van balance stays the same. Avoid in-tank pumps. Ensure shower is 50mm or so above van floor to assist drainage. JMHO. Cheers.
5,272
We find the onboard tank a great asset. During winter touring the water is warmer, ie less chance of freezing. The pressure at the shower head is greater as the pump doesn't have to pull the water up from the aquaroll. SWMBO doesn't have to send me out so often, night time for a refill.
I've said in another thread Bailey have made a big mistake abandoning the onboard tank in their Unicorn 2
I also thnk the onboard tank is a real asset, for a start i only have to take 1 aquaroll away with me.
I am able to draw from the onboard or aquaroll so the last day the i never refill the onboard tank so dont have to empty before i leave.
I always dry the tank out when not being used and leave the cap off, as i noticed it still left about 1/2 inch of water in the bottom when drained.
I thought the underslung tanks were a very good idea so didnt waste space inside, shame they seem to have stopped fitting them?
I also let the level run down on the day before leaving and empty the aquaroll so that its stored away the day before
The aquaroll for waste water is emptied and replaced with a bucket the night before leaving and stored away as its one less job to do in the rain the next morning
I used to fit my tanks underslung but in the present van there is plenty of underbed room so the 75 litre Fiamma tank is inboard under the nearside front bed
Jan 31, 2011
316
To tow with less than a full tank will cause the water to "slosh about"
The only way to stop it "sloshing" would be to fill the tank, then the water & tank become a solid mass
We carry 1600 litres of water in our appliance tanks, & even though the tanks have baffles to stop the "sloshing", we keep the tank topped up at all times.
I have a 40ltr inboard cold tank & a 10ltr hot water tank in my Burstner that are empty when traveling
5,272
PaulT said:
1600 litres!!!! One and half tonnes!! Isn't that a bit excessive?
Whoops!
Surely 0.161 tonnes???
The MTPLM of my Wyoming is 1670kgs.
I think you may have had too many sherberts?
Feb 3, 2008
3,790
Willi-Wonti said We carry 1600 litres of water in our appliance tanks,
The clue is in his avatar, he is a fireman talking about the fire engine, not his caravan.
Dustydog - yes 1600 litres do weigh 1.6 tonnes.
(Update - Sprocket beat me to it
Jan 31, 2011
316
Our pumps will pump 1000 gallons of water per min (4500 ltr)
By using 1 hose reel the tank will last for about 12 mins. 2 hose reels 6 mins, and the big hose about 1.5 min
Thats why we have to carry so much water till we can find a hydrant
Aug 9, 2010
1,426
My Royale has two underfloor tanks, totalling 12 gallons, but I've never used them.I prefer to pump straight out of the Aquaroll. Using the tanks means that you either fill them at home, therefore carrying all that extra weight, or fill them on site, which means filling the Aquaroll, pumping it into the tank, then when you use the water, pumping it back out again! That means using twice the battery power.Don't see the point.
Jun 2, 2017
141
yeezy boost 350
jerseys cheap
coach outlet online
heat jerseys
phillies jerseys
cowboys jerseys
hermes bags
discount nike shoes
oakley sunglasses outlet
michael kors outlet store
louis vuitton bags
yeezy boost
mont blanc pen
michael kors outlet
adidas uk
birkenstock outlet
louboutin pas cher
nike outlet
toms
burberry outlet online
kate spade handbags
purs jerseys
adidas outlet store
cheap jerseys
toms
coach factory outlet online
cheap nike sneakers
nfl jerseys
louboutin outlet
longchamps
air max outlet
ralph lauren sale
adidas running shoes
coach handbags outlet
birkenstock shoes
coach outlet online
true religion
pandora charms
fitflop shoes
nike outlet store
ralph lauren outlet
adidas nmd r1
yeezy shoes
air max
nike outlet store
coach outlet online
michael kors
coach outlet store online clearance
hermes bag
kate spade bags
moncler uk
versace
cheap jordans for sale
prada outlet online
ralph lauren outlet online
louis vuitton factory outlet
gucci borse
mont blanc pen
swarovski sale
coach outlet online
kate spade outlet online
mulberry uk
coach purses
jordans
tory burch outlet online
adidas outlet online
giants jerseys
adidas nmd runner
gucci outlet online
adidas nmd runner
adidas outlet store
yeezy boost 350
beats by dre
rolex replica watches
nike outlet
moncler uk
gucci handbags outlet
ralph lauren sale
coach outlet store
kd shoes
cheap jordan shoes
polo ralph lauren outlet online
sac longchamp
burberry outlet store
ralph lauren outlet
kate spade outlet store
harden shoes
pandora jewelry
pandora charms sale clearance
michael kors handbags outlet
polo ralph lauren
christian louboutin
dansko outlet
texans jerseys
ralph lauren sale
fitflops
fendi bags
air max 90
dodgers jerseys
eltics jerseys
louis vuitton outlet online
longchamp bag
rolex replica watches for sale
chaussures louboutin
nike free 4.0 flyknit
rolex watches
coach outlet store
yankees jerseys
montblanc
pandora charms
fitflops sale clearance
pandora
coach outlet online
nike free run flyknit
nfl jerseys cheap
curry shoes
ray ban sunglasses outlet
christian louboutin outlet
adidas nmd runner
nike air max 95
marc jacobs
christian louboutin shoes
adidas ultra boost
ray ban sunglasses discount
cheap jordan shoes
adidas superstars
hermes outlet online
oakley sunglasses on sale
cardinals jerseys
michael kors outlet clearance
abercrombie outlet
marc jacobs outlet
hermes outlet
cheap rolex watches
pandora charms
air max 90
nike free run
nike outlet store online
longchamp handbags
yeezy boost
true religion jeans
ralph lauren sale
tory burch sale
coach outlet online
fitflops clearance
air max
cheap jordan shoes
michael kors outlet online
nike sneakers
coach outlet online
yeezy boost 350
louboutin outlet
coach outlet online
gucci outlet online
air jordans
coach outlet store
discount oakley sunglasses
moncler pas cher
polo ralph lauren
mulberry bags
sac louis vuitton pas cher
coach outlet online
ray bans
michael kors bags
adidas
toms outlet
coach outlet store
michael kors
mont blanc pens
broncos jerseys
sac louis vuitton
birkin handbags
swarovski uk
fake rolex watches
clarks shoes outlet
wireless beats headphones
salomon boots
birkenstock outlet
ralph lauren
jordan shoes
fit flops
coach outlet store
louis vuitton outlet store
adidas nmd r1
gucci
red bottom shoes for women
mulberry handbags
adidas nmd r1
christian louboutin sale
swarovski crystals
ralph lauren outlet
rangers jerseys
mulberry outlet uk
mlb jerseys
true religion jeans outlet
pandora jewelry outlet
fitflops clearance
beats wireless headphones
burberry sale
bercrombie
tods outlet
fitflop shoes
cheap nike shoes
cheap nfl jerseys
kd 8 shoes
salomon outlet
nike outlet online
burberry outlet
michael kors bags
jimmy choo shoes
ed hardy store
fred perry polo shirts
cheap oakley sunglasses
valentino outlet
pandora charms outlet
air max shoes
nike store
dolce and gabbana outlet online
yeezy boost
toms outlet
fitflops sale
michael kors outlet canada
nike roshe one
gucci
49ers jerseys
moncler jackets
mbt
michael kors
ralph lauren outlet
adidas
yeezy boost 350
nike air max
yeezy 350 boost
michael kors bags
ralph lauren
patriots jerseys
adidas nmd r1
michael kors uk
coach outlet online
nike blazer low pas cher
pandora bracelet
nike air max 95
red sox jerseys
gucci bags
coach outlet online
air jordan shoes
nike flyknit
christian louboutin
mulberry uk
moncler outlet online
levis outlet
toms
nike roshe shoes
longchamp soldes
longchamp outlet store
hollister clothing
coach outlet canada
lakers jerseys
kate spade uk
longchamp bags
michael kors
ralph lauren sale clearance uk
moncler jackets
chi flat iron
jordan shoes
hermes bags
polo ralph lauren
mulberry
ralph lauren
clarks shoes outlet
coach outlet online
nfl jerseys
coach outlet
michael kors
mlb jerseys
adidas sneakers
longchamp bags
adidas store
hollister kids
beats headphones
nike cortez classic
tigers jerseys
warriors jerseys
pandora jewelry
salomon outlet
cheap air jordans
longchamp pliage
nike air force
michael kors outlet
louis vuitton purses
michael kors
nfl jerseys wholesale
adidas superstars
packers jerseys
longchamp handbags
fitflops sale
michael kors
red bottom
pandora outlet
white sox jerseys
fitflops sale
mbt
air max
clarks
nmd adidas
cheap ray ban sunglasses
coach outlet online
adidas yeezy boost 350
burberry outlet
cavaliers jerseys
air jordans
adidas sneakers
true religion outlet online
fred perry shirts
adidas trainers
polo ralph lauren pas cher
cheap jordan shoes
pandora jewelry store
red bottom heels
eahawks jerseys
ed hardy outlet
coach outlet online
louboutin shoes
nike uk
clarks shoes for women
parada bags
longchamp sale
yeezy shoes
bulls jerseys
moncler coats
nike outlet store
vans outlet
vans store
timberland boots outle
ray ban glasses
christian louboutin pas cher
cheap jordan shoes
rolex watches
jordan retro
yeezy boost
oakley sunglasses wholesale
nike tn pas cher
jordan femmes pas cher
rockets jerseys
cheap rolex replica watches
adidas nmd runner
montblanc pens
coach outlet online
gucci bags
birkenstock uk
adidas yeezy boost
thunder jerseys
jordan uk
louboutin outlet
birkenstocks
sac longchamp
ghd straighteners sale
adidas yeezy boost
coach outlet online
fitflop
adidas yeezy boost
birkenstock
celine outlet online
air max 90
fitflop
birkenstock outlet
ed hardy clothing
nike sneakers
fit flops
louboutin shoes
ray ban sunglasses cheap
ed hardy uk
adidas trainers
ralph lauren
chaussure louboutin pas cher
ghd hair
nike air huarache
ray bans
yeezy boost 350 v2
ray ban glasses
coach outlet online
coach factory outlet store
adidas superstar trainers
michael kors
polo ralph lauren
adidas superstar shoes
mlb jerseys whgolesale
pandora charms sale
tods shoes
birkenstocks
celine handbags
yeezy shoes
red bottom
kate spade outlet
kate spade bags
mbt
fitflops sandals
mlb jerseys
coach outlet online
cheap air max
longchamp bags
dansko
adidas sneakers
michael kors uk
adidas yeezy boost
cubs jerseys
ralph lauren uk
coach outlet online
fit flops
louboutin outlet
kate spade purses
pandora charms sale
xwedef
