SirRogerFFS said:
Hi Prof ..... Sadly John this shurflo is non adjustable It is something we had looked at in recent times.Its a strange thing that happens if you fully open the hot tap it doesnt create the knocking through the system. But when you part open the tap it does knock and runs on when you close the tap.I have got the pump running quietly when taps are open now but to go along with problem which I am fairly sure it is the pump when I drain the water down its has loads of air in before water runs .
Thanks for you input
Sir Roger
The knocking description you have just added sound more like an airlock or air hammer somewhere in the system. It is just possible the essential air cap in the water heater and the length and size of the pipes and the power of the pump have just coincided to produce a resonant system. This could be brought on by running the system at a slightly higher pressure. This thought is supported by your report that when you fully open the system is quiet, but when only part open the flow resistance is enough to allow the pump to run up to trip pressure which starts the hammer.
I don't know which water heater you have, but all the Carver and Truma models were designed to have an air cap at the top to allow for the expansion of cold water as it was heated. This was achieved by having the water exit point a few cm below the top of the tank. After drain down the first refill needed to fill the tank and the entry of the cold water would displace the air in the tank until the water level reached the take off point. Obviously the hot taps needed to be open to allow the air to escape. The first few times some hot water was drawn off, it would often en train a little air from the air cap causing bubbles, but this would subside over the first 3 or 4 heating and take off cycles and is not usually a problem.
If some of that air has become trapped in a pipe that has not been properly vented, it may be reacting with pump pressure.
Check the priming instructions for you water heater, I hope you have tried opening ALL the taps and shower at the same time until you only get water and no air. Then closing them one at a time starting with the taps nearest to the pump.
There is nothing stopping you from fitting a whale type pressure switch just after the pump. These of course can be set at a lower pressure and might just cure the hunting problem.
What I cant explain is the amounts of air you have describe when draining down. Like Gaffer I do wonder if you have a leak somewhere on the system? Where I do deviate form gaffers thinking is generally with these diaphragm pumps the peak pressure they develop on every cycle would almost always cause a visible water leak. Do you have any water leaks anywhere, dripping taps, water heater vent valves, anything??
